cgal-discuss - Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start
  • To:
  • Subject: Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start
  • Date: Tue, 5 Jan 2010 17:18:31 +0100
On Tuesday 05 January 2010 16:40:00 Maarten Moesen wrote:
> CURIOUSLY:
> Curiously, if we comment out the line:
> // std::cout << "Point: " << p << std::endl;
> in release mode, the program compiles, links, and runs sucessfully and
> depends.exe finds both DLLs without any problem.
If you do not comment out that line, then the executable depends on
MSVCP80.DLL. Does depends.exe correctly find that library?
Do you see something with depends.exe that can be an incorrect dependency
(such as MSVCP80.DLL from MSVS2005 pre-sp1)?
Laurent Rineau, PhD
