- To:
- Subject: Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start
- Date: Wed, 6 Jan 2010 09:29:25 +0100
On Tuesday 05 January 2010 20:17:46 Maarten Moesen wrote:
> Dear Laurent,
> Thank you for your quick reply!
> We indeed confirmed that the MSVCP80.DLL is pre-SP1.
> We'll try reinstalling SP1 (or the VS2005 redistributable).
> Any suggestion how to fix this is surely welcome ;)
Verify that your MSVS has the last patches. Then, make sure that last
vcredist
for last VC80 is install. As I am not really a user of Windows products, I
cannot give you more information about the precise way to proceed.
Or upgrade to VC90! ;-) VC10 is about to be released (beta stage for now).
Laurent Rineau, PhD
- [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Laurent Rineau (GeometryFactory), 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/05/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Laurent Rineau (GeometryFactory), 01/06/2010
- [cgal-discuss] a question about setup cgal3.5.1.exe, mycug, 01/06/2010
- Re: [cgal-discuss] a question about setup cgal3.5.1.exe, Laurent Rineau (GeometryFactory), 01/06/2010
- Re: [cgal-discuss] after install cgal MSVC 2005 : application failed to start, Maarten Moesen, 01/07/2010
