- To:
- Subject: Re: [cgal-discuss] error in install cgal on linux
- Date: Fri, 15 Jan 2010 13:37:58 +0100
- Organization: INRIA
mahdavi wrote:
hi all,...
I install cgal on linux by instructions in manual cgal ,but I don't run a
simple program by cgal ,I am beginner programmer in linux , when I type
vector_convex_hull_2.cpp in run command ,and follow message is occur:
g++ vector_convex_hull_2.cpp
please help me ,may do not install cgal completely or no? thank and best
regard.
You also need to link with the library. Add -lCGAL to the command line.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
- [cgal-discuss] error in install cgal on linux, mahdavi, 01/15/2010
- Re: [cgal-discuss] error in install cgal on linux, Sylvain Pion, 01/15/2010
- Re: [cgal-discuss] error in install cgal on linux, mahdavi, 01/15/2010
- Re: [cgal-discuss] error in install cgal on linux, Martin Baeker, 01/15/2010
- Re: [cgal-discuss] error in install cgal on linux, Daniel Duque, 01/15/2010
- Re: [cgal-discuss] error in install cgal on linux, mahdavi, 01/16/2010
