cgal-discuss - Re: [cgal-discuss] error in install cgal on linux
  • To:
  • Subject: Re: [cgal-discuss] error in install cgal on linux
  • Date: Fri, 15 Jan 2010 23:42:10 -0800 (PST)
thanks for your help,
thank and best regard.
Daniel Duque wrote:
> Hi,
>>and I copy scripts/cgal_create_cmake_script
>>to my working directory
> No, no need to copy it. Run it. Type:
> ~/CGAL-3.5/scripts/cgal_create_cmake_script
> Also,
>>CMake Error: The source directory "/root/Projects/exa/src" does not appear
> You know logging as root is frown upon in linux, don't you? You may want
> to consider a linux tutorial, there are many nice ones.
> Best,
> Daniel
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
View this message in context:
http://n4.nabble.com/error-in-install-cgal-on-linux-tp1014785p1015513.html
