- To: ,
- Subject: Re: [cgal-discuss] Infinite vertex in Triangulations
- Date: Mon, 18 Jan 2010 14:25:22 +0100
I know that every domain can be triangulated, but i'm not sure if all of
those triangulations can be represented by the CGAL-datastructures (using the
infinite vertex).
In my specific case, i use the incremental builder to generate the
triangulation datastructure out of a tet soup without adjacency information.
In one case, the incremental builder crashes as it is not able to reconstruct
the adjacency information for the infinite cells. But the source of this
(specific) data is the 3D-Mesh Generation package, where I only use cells
from inside the complex as input. That may be a bug in the incremental
builder, but first of all i wanted to be sure that this representation can
handle all cases.
Thank you for your answers.
-------- Original-Nachricht --------
> Datum: Sat, 16 Jan 2010 15:26:26 -0500
> Von: Panagiotis Foteinos
> An:
> Betreff: Re: [cgal-discuss] Infinite vertex in Triangulations
> Are you referring to a specific family of triangulations (for example
> Delaunay)? If not, then every domain can be triangulated.
> On Sat, Jan 16, 2010 at 12:16 PM, Daniel Weber
> wrote:
> > Hi,
> > I know that the infinite vertex in triangulations is used to generalize
> > insertions of vertices without taking care about the location of the new
> > vertex (inside / outside the domain). Are there any cases, where this
> kind
> > of modelling fails, meaning that a triangulation of a domain cannot be
> > represented?
> > I could imagine that some triangulations of concave domains cannot be
> > represented. Does anybody know papers discussing those issues?
> > Thank you,
> > Daniel
> > GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> > Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://lists-sop.inria.fr/wws/info/cgal-discuss
Preisknaller: GMX DSL Flatrate für nur 16,99 Euro/mtl.!
http://portal.gmx.net/de/go/dsl02
- [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/16/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Panagiotis Foteinos, 01/16/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/18/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Panagiotis Foteinos, 01/18/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/19/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Nico Kruithof, 01/19/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/21/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Nico Kruithof, 01/24/2010
