- To:
- Subject: Re: [cgal-discuss] Infinite vertex in Triangulations
- Date: Tue, 19 Jan 2010 18:26:09 +0100
Hi,
i use the incremental builder (CGAL/Triangulation_incremental_builder_3.h) to
reconstruct the adjacency information. This algorithm crashes during the
reconstruction of inifite cell adjacency. Now, I want to find out why
"Triangulation_incremental_builder_3" crashes. Maybe I should post a minimal
code snipplet, which causes this crash.
-------- Original-Nachricht --------
> Datum: Mon, 18 Jan 2010 13:28:30 -0500
> Von: Panagiotis Foteinos
> An:
> Betreff: Re: [cgal-discuss] Infinite vertex in Triangulations
> CGAL triangulation datastructure (TDS) can represent any triangulation.
> How do you know that the adjacency information for the infinite cells is
> not correct? Generally, there is not a unique way to triangulate
> domains; therefore, it is hard to determine the connectivity correctness
> by just visiting the cells.
> Regards
> Daniel Weber wrote:
> > I know that every domain can be triangulated, but i'm not sure if all of
> those triangulations can be represented by the CGAL-datastructures (using
> the infinite vertex).
> > In my specific case, i use the incremental builder to generate the
> triangulation datastructure out of a tet soup without adjacency
> information. In
> one case, the incremental builder crashes as it is not able to reconstruct
> the adjacency information for the infinite cells. But the source of this
> (specific) data is the 3D-Mesh Generation package, where I only use cells
> from inside the complex as input. That may be a bug in the incremental
> builder, but first of all i wanted to be sure that this representation can
> handle
> all cases.
> > Thank you for your answers.
> >> Datum: Sat, 16 Jan 2010 15:26:26 -0500
> >> An:
> >> Are you referring to a specific family of triangulations (for example
> >> Delaunay)? If not, then every domain can be triangulated.
> >> On Sat, Jan 16, 2010 at 12:16 PM, Daniel Weber
> wrote:
> >>> Hi,
> >>> I know that the infinite vertex in triangulations is used to
> generalize
> >>> insertions of vertices without taking care about the location of the
> new
> >>> vertex (inside / outside the domain). Are there any cases, where this
> >> kind
> >>> of modelling fails, meaning that a triangulation of a domain cannot be
> >>> represented?
> >>> I could imagine that some triangulations of concave domains cannot be
> >>> represented. Does anybody know papers discussing those issues?
> >>> Thank you,
> >>> Daniel
> >>> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> >>> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> >>> You are currently subscribed to cgal-discuss.
> >>> To unsubscribe or access the archives, go to
> >>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/16/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Panagiotis Foteinos, 01/16/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/18/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Panagiotis Foteinos, 01/18/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/19/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Nico Kruithof, 01/19/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] Infinite vertex in Triangulations, Daniel Weber, 01/21/2010
- Re: [cgal-discuss] Infinite vertex in Triangulations, Nico Kruithof, 01/24/2010
