- To:
- Subject: [cgal-discuss] Howto adapt my mesh for parameterization.
- Date: Tue, 26 Jan 2010 17:05:09 +0100 (CET)
Hello,
I'm using CGAL's parameterization package.
There's a very nice page explaining how to use if with OFF files, but that's
not my case.
So, instead of loading a mesh from a file, I'm trying to pass my vertices and
faces to CGAL.
My data is formatted in a opengl typical pattern. I have a vertex array, one
or
more arrays of triangular faces. These faces contain no more than indexes to
the vertex array.
What I'm doing is to pass the face like:
typedef CGAL::... Poly;
Poly poly;
for all my faces
get the face vertexes (pa, pb and pc)
poly.make_triangle(Point(pa.x, pa.y, pa.z), Point(pb.x, pb.y, pb.z),
Point(pc.x, pc.y, pc.z));
Of course this repeats vertexes (points), and does not give any information
about the faces connectivity.
In the end, running the algorithm I get: "Parameterization requires a convex
border"
The mesh I'm using right now is just a couple of coplanar triangles, or if you
want, a tessellated unit square.
But I can't seem to be able to find how to pass the vertexes and the faces
separately.
Nor do I know how to specify the border.
Is there an example of this somewhere?
I am searching the examples and demos, but some help would be greatly
appreciated.
Thank you
Paulo
- [cgal-discuss] Howto adapt my mesh for parameterization., paulo.jnkml, 01/26/2010
- Re: [cgal-discuss] Howto adapt my mesh for parameterization., Laurent Saboret, 01/27/2010
- Re: [cgal-discuss] Howto adapt my mesh for parameterization., paulo, 01/30/2010
