- To:
- Subject: Re: [cgal-discuss] Construct polygon_set_base with polygon_base
- Date: Wed, 03 Feb 2010 15:08:31 +0200
?? wrote:
> Hi, everyone
> I come across some difficulties when computing the intersection of two
> polygon_set_base, the speed of joining is so slow that I cannot do
> anything with it.
> As far as I am concerned, I guess the reason is the constructing
> function of the Polygon_set_base , the parameter is a Polygon_base.I
> am looking forward to your reply~Thank you~
your reply on what? There is no question neither there are any details.
> ?????????????????????????????????????? <http://www.yeah.net/?from=o1>
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] Construct polygon_set_base with polygon_base, 萌, 02/03/2010
- Re: [cgal-discuss] Construct polygon_set_base with polygon_base, Efraim Fogel, 02/03/2010
- Re:Re: [cgal-discuss] Construct polygon_set_base with polygon_base, 萌, 02/03/2010
