[cgal-discuss] Arrangement_on_surface_2: Precondition exception when removing edges
- To:
- Subject: [cgal-discuss] Arrangement_on_surface_2: Precondition exception when removing edges
- Date: Wed, 3 Feb 2010 07:29:44 -0800 (PST)
Hi Everybody!
I am having problems removing edges from an arrangement.
Is the assumption correct that I should be able to delete all the edges from
an arrangement in any order without violating any preconditions inside the
implementation of Arrangement_on_surface_2?
To put it another way: Are there any rules I have to follow when deleting
edges from an arrangement?
I isolated a (quite) simple test case where deleting edges from an
arrangement leads to a precondition violation exception.
I tried to compile and run the code in two different working environments
but the problem stays intact.
Windows XP / Visual Studio 8.0 / CGAL 3.5
] CGAL error: assertion violation!
] Expression : ic1 != NULL && ic1 == ic2
] File :
CGAL-3.5\include\CGAL/Arrangement_2/Arrangement_on_surface_2_impl.h
] Line : 4011
] Explanation:
Debian Linux / gcc version 3.4.4 / CGAL 3.5.1
] terminate called after throwing an instance of 'CGAL::Assertion_exception'
] what(): CGAL ERROR: assertion violation!
] Expr: ic1 != NULL && ic1 == ic2
] File:
/usr/local/include/CGAL/Arrangement_2/Arrangement_on_surface_2_impl.h
] Line: 4011
] Aborted
A self contained test case in a single c++ source file can be downloaded
http://www.student.tugraz.at/mmoerth/cgal/arrproblem.cpp
Types used in the test:
] typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
] typedef Kernel::Point_2 Point;
] typedef CGAL::Arr_segment_traits_2< Kernel > ArrangementTraits;
] typedef CGAL::Arrangement_2< ArrangementTraits > Arrangement;
] typedef ArrangementTraits::X_monotone_curve_2 ArrangementSegment;
] typedef Arrangement::Edge_iterator ArrangementEdgeIter;
If I can do anything to help sort this out just let me know.
Thanks for any help or comments on this issue!
Martin
View this message in context:
http://n4.nabble.com/Arrangement-on-surface-2-Precondition-exception-when-removing-edges-tp1461262p1461262.html
- [cgal-discuss] Arrangement_on_surface_2: Precondition exception when removing edges, Martin Mörth, 02/03/2010
