- To:
- Subject: Re:Re: [cgal-discuss] Construct polygon_set_base with polygon_base
- Date: Wed, 3 Feb 2010 23:38:24 +0800 (CST)
why the speed of intersection is so slow,is there ant restirction on the 2D polygon intersection
在2010-02-03 21:08:31,"Efraim Fogel" <> 写道: >萌 wrote: >> Hi, everyone >> I come across some difficulties when computing the intersection of two >> polygon_set_base, the speed of joining is so slow that I cannot do >> anything with it. >> As far as I am concerned, I guess the reason is the constructing >> function of the Polygon_set_base , the parameter is a Polygon_base.I >> am looking forward to your reply~Thank you~ >your reply on what? There is no question neither there are any details. >> >> >> ------------------------------------------------------------------------ >> 网易邮箱,没有垃圾邮件的免费电子邮箱! <http://www.yeah.net/?from=o1> > > >-- > ____ _ ____ _ > /_____/_) o /__________ __ // > (____ ( ( ( (_/ (_/-(-'_(/ > _/ > > > >-- >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss >
- [cgal-discuss] Construct polygon_set_base with polygon_base, 萌, 02/03/2010
- Re: [cgal-discuss] Construct polygon_set_base with polygon_base, Efraim Fogel, 02/03/2010
- Re:Re: [cgal-discuss] Construct polygon_set_base with polygon_base, 萌, 02/03/2010
