- To:
- Subject: Re: [cgal-discuss] Surface Reconstruction - build issues
- Date: Sun, 7 Feb 2010 12:33:00 +0100
Le dimanche 07 février 2010 11:58:05, 杨成林 a écrit :
> Cmake doesn't generate makefile for examples by default. You should
> manually set it.
It depends if you are configuring the whole CGAL library (in that case demos
and examples are configured only if WITH_DEMOS=ON and WITH_EXAMPLES=ON, in
the
CMake cache), or if you are configuring a single example. In that case, it
was
the configuration of a single example in
examples/Surface_reconstruction_points_3/.
Laurent Rineau, PhD
- [cgal-discuss] Surface Reconstruction - build issues, KOUMANTARIS, 02/05/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Panagiotis Foteinos, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, 杨成林, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Rineau (GeometryFactory), 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/08/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Rineau (GeometryFactory), 02/12/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/12/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/15/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Saboret, 02/22/2010
