- To:
- Subject: Re: [cgal-discuss] Surface Reconstruction - build issues
- Date: Fri, 12 Feb 2010 16:09:44 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=iXweHLSvvmZOqyIYw3Th6Haormgha6rJMLkJrW4vQOnbTKWynmcXHSzTxd84DcoV7O tt9gkfv5rH8Ozi94CkUsp3Cmr2gqKgIAsVcwRcqM9eJ0SZEZ985AROifp13P9xLBUBE+ 3JhtXK4gzwUhBJecDIK7WEPxk32R7QpFy1V0s=
Hello,
I can not find WITH_DEMOS=ON and WITH_EXAMPLES=ON in the
CMakeCache.txt . I included them my self and build again but still i
have the same problem.
2010/2/12 Laurent Rineau (GeometryFactory)
> On Monday 08 February 2010 02:18:23 George Koumantaris wrote:
>> shouldn't i run into some errors about missing components, instead of
>> getting a clean build?
> The CMake scripts give *warnings* about missing dependencies, but no errors.
> The reason is that CGAL must be buildable with WITH_DEMOS=ON and
> WITH_EXAMPLES=ON even if there are (minor) missing dependencies (for
> example,
> even if you do not have Qt3, you want to be able to build Qt4 demos).
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Surface Reconstruction - build issues, KOUMANTARIS, 02/05/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Panagiotis Foteinos, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, 杨成林, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Rineau (GeometryFactory), 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/07/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/08/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Rineau (GeometryFactory), 02/12/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/12/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, George Koumantaris, 02/15/2010
- Re: [cgal-discuss] Surface Reconstruction - build issues, Laurent Saboret, 02/22/2010
