cgal-discuss - Re: [cgal-discuss] Example of vertex item for convex_hull_3 function
  • To:
  • Subject: Re: [cgal-discuss] Example of vertex item for convex_hull_3 function
  • Date: Mon, 15 Feb 2010 15:21:00 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=sYNowtcTa6ioIWv5N3PPAYbhkLITDh/eAs5DwXZW69I3oms0PyNpmtDFmgijboPWWJ 3t9Pz+HsMvkNYSWKWT0hL0mCXZ3aRSD/urkmQSEOKdvVAFaolVrSfEgHMQ6MoNmq16cT 0eRIe7zy5wygroLGh5cdAepw1brxto3cUW/2U=
Thanks a lot for the quick answer.
Unfortunately I need a convex hull because I need to find a Delaunay
triangulation of points onto a sphere.
However I just read a post by Monique Teillaud about spherical
Delaunay triangulations: do you know if it is already possible to use
the spherical kernel to compute Delaunay triangulations?
I will write my own kernel (thanks for the link, I would not have had
a look so deep in CGAL without it) and it would be a good exercise to
improve my CGAL capabilities.
- best regards,
Manuel
On Mon, Feb 15, 2010 at 3:06 PM, Sebastien Loriot (GeometryFactory)
wrote:
> Hello,
> It may not fit your need, but a simple solution is to use
> Delaunay_triangulation_3 and a vertex_with_info to compute the convex hull
> of your 3D points.
> The customization of the vertex is described here:
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_35.6.2
> to set the info you need to write something like:
>  Vertex_handle v=t.insert(pt);
>  v->info()=something;
> then the vertices on the convex_hull can be retrieve using the vertices
> adjacent to the infinite vertex, like this:
>  t.adjacent_vertices(t.infinite_vertex(), output_iterator);
> If you really need to use the Convex_hull_3 package, then you will probably
> have to defined your own kernel as described here:
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Kernel_23/Chapter_main.html#Section_9.5
> S.
> wrote:
>> Dear CGAL users,
>> I want to attach an item per vertex to a set of points for which I want
>> the
>> convex hull (let say an index).
>> I have understood that I need to refine CGAL::Polyhedron_items_3 as in the
>> examples:
>> examples/Polyhedron/polyhedron_prog_color.cpp
>> examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp
>> however in these examples, the custom field of the face/edge is filled
>> after
>> the construction, but I would like to provide a point with the appropriate
>> index before a call to convex_hull_3.
>> It probably means that I have to define my own kind of point (probably
>> derived
>> from one of the CGAL class).
>> As I am not sure if this is even possible, I would be really happy if
>> somebody
>> can share her/his experience with such a problem such that I can switch to
>> an
>> other implementation as quickly as possible if my understanding is
>> correct.
>> Is there an example of such a specialization somewhere in the
>> documentation
>> that I missed?
>> Did somebody already have solved this kind of problem?
>> - thank you in advance,
>> Manuel
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
