- To:
- Subject: Re: [cgal-discuss] Example of vertex item for convex_hull_3 function
- Date: Mon, 15 Feb 2010 15:48:42 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type:content-transfer-encoding; b=Tc5Ihb3m5WPBY/npk6Ra2+bM3uOUUFm+ZAjvAG9eAGa39Nx5PVMoqbK1d0a/37EqkU AkHKXJ/yw8zQ+WYh/6kZpYSGVzWA9aOXAuRrvqQiQpJke224pQzunHZ5QZtjN67iChn9 U1lujAvYArhjVS8IKK2MasXD+U26Vf8KnWmTA=
Thanks a lot.
Manuel
On Mon, Feb 15, 2010 at 3:38 PM, Sebastien Loriot (GeometryFactory)
wrote:
> Manuel Yguel wrote:
>> Thanks a lot for the quick answer.
>> Unfortunately I need a convex hull because I need to find a Delaunay
>> triangulation of points onto a sphere.
>> However I just read a post by Monique Teillaud about spherical
>> Delaunay triangulations: do you know if it is already possible to use
>> the spherical kernel to compute Delaunay triangulations?
> Not yet but as written in this tech report and as I said you can use the
> Delaunay Triangulation 3 for this purpose.
> If you need triangles, you can use the method:
> t.incident_cells ( t.infinite_vertex(), output_iterator)
>> I will write my own kernel (thanks for the link, I would not have had
>> a look so deep in CGAL without it) and it would be a good exercise to
>> improve my CGAL capabilities.
>> - best regards,
>> Manuel
>> On Mon, Feb 15, 2010 at 3:06 PM, Sebastien Loriot (GeometryFactory)
>> wrote:
>>> Hello,
>>> It may not fit your need, but a simple solution is to use
>>> Delaunay_triangulation_3 and a vertex_with_info to compute the convex
>>> hull
>>> of your 3D points.
>>> The customization of the vertex is described here:
>>> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_35.6.2
>>> to set the info you need to write something like:
>>> Vertex_handle v=t.insert(pt);
>>> v->info()=something;
>>> then the vertices on the convex_hull can be retrieve using the vertices
>>> adjacent to the infinite vertex, like this:
>>> t.adjacent_vertices(t.infinite_vertex(), output_iterator);
>>> If you really need to use the Convex_hull_3 package, then you will
>>> probably
>>> have to defined your own kernel as described here:
>>> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Kernel_23/Chapter_main.html#Section_9.5
>>> S.
>>> wrote:
>>>> Dear CGAL users,
>>>> I want to attach an item per vertex to a set of points for which I want
>>>> the
>>>> convex hull (let say an index).
>>>> I have understood that I need to refine CGAL::Polyhedron_items_3 as in
>>>> the
>>>> examples:
>>>> examples/Polyhedron/polyhedron_prog_color.cpp
>>>> examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp
>>>> however in these examples, the custom field of the face/edge is filled
>>>> after
>>>> the construction, but I would like to provide a point with the
>>>> appropriate
>>>> index before a call to convex_hull_3.
>>>> It probably means that I have to define my own kind of point (probably
>>>> derived
>>>> from one of the CGAL class).
>>>> As I am not sure if this is even possible, I would be really happy if
>>>> somebody
>>>> can share her/his experience with such a problem such that I can switch
>>>> to
>>>> an
>>>> other implementation as quickly as possible if my understanding is
>>>> correct.
>>>> Is there an example of such a specialization somewhere in the
>>>> documentation
>>>> that I missed?
>>>> Did somebody already have solved this kind of problem?
>>>> - thank you in advance,
>>>> Manuel
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Example of vertex item for convex_hull_3 function, manuel.yguel, 02/15/2010
- Re: [cgal-discuss] Example of vertex item for convex_hull_3 function, Sebastien Loriot (GeometryFactory), 02/15/2010
- Re: [cgal-discuss] Example of vertex item for convex_hull_3 function, Manuel Yguel, 02/15/2010
