cgal-discuss - Re: [cgal-discuss] Example of vertex item for convex_hull_3 function
  • To:
  • Subject: Re: [cgal-discuss] Example of vertex item for convex_hull_3 function
  • Date: Mon, 15 Feb 2010 15:38:46 +0100
Manuel Yguel wrote:
Thanks a lot for the quick answer.
Unfortunately I need a convex hull because I need to find a Delaunay
triangulation of points onto a sphere.
However I just read a post by Monique Teillaud about spherical
Delaunay triangulations: do you know if it is already possible to use
the spherical kernel to compute Delaunay triangulations?
Not yet but as written in this tech report and as I said you can use the Delaunay Triangulation 3 for this purpose.
If you need triangles, you can use the method:
t.incident_cells ( t.infinite_vertex(), output_iterator)
I will write my own kernel (thanks for the link, I would not have had
a look so deep in CGAL without it) and it would be a good exercise to
improve my CGAL capabilities.
- best regards,
Manuel
On Mon, Feb 15, 2010 at 3:06 PM, Sebastien Loriot (GeometryFactory)
wrote:
Hello,
It may not fit your need, but a simple solution is to use
Delaunay_triangulation_3 and a vertex_with_info to compute the convex hull
of your 3D points.
The customization of the vertex is described here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Subsection_35.6.2
to set the info you need to write something like:
Vertex_handle v=t.insert(pt);
v->info()=something;
then the vertices on the convex_hull can be retrieve using the vertices
adjacent to the infinite vertex, like this:
t.adjacent_vertices(t.infinite_vertex(), output_iterator);
If you really need to use the Convex_hull_3 package, then you will probably
have to defined your own kernel as described here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Kernel_23/Chapter_main.html#Section_9.5
S.
wrote:
Dear CGAL users,
I want to attach an item per vertex to a set of points for which I want
the
convex hull (let say an index).
I have understood that I need to refine CGAL::Polyhedron_items_3 as in the
examples:
examples/Polyhedron/polyhedron_prog_color.cpp
examples/Surface_mesh_simplification/edge_collapse_enriched_polyhedron.cpp
however in these examples, the custom field of the face/edge is filled
after
the construction, but I would like to provide a point with the appropriate
index before a call to convex_hull_3.
It probably means that I have to define my own kind of point (probably
derived
from one of the CGAL class).
As I am not sure if this is even possible, I would be really happy if
somebody
can share her/his experience with such a problem such that I can switch to
an
other implementation as quickly as possible if my understanding is
correct.
Is there an example of such a specialization somewhere in the
documentation
that I missed?
Did somebody already have solved this kind of problem?
- thank you in advance,
Manuel
