- To:
- Subject: [cgal-discuss] installing cgal on windows
- Date: Tue, 16 Feb 2010 17:37:46 +0100 (CET)
Hello All,
I am a newbie so hope you don't mind if I ask a primary question.
I am using windows XP (professional) , visual studio 9.0 and can't get cgal
installed !!!
I am following the instructions given here:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
everything seems to be fine and I can configure/generate using cmake . but
when
I try to make the solution (CGAL.sln) visual studio gives me millions of
error,
most of them are like:
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(280) : error C2061: syntax
error : identifier 'intmax_t'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(282) : error C2061: syntax
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(283) : error C2061: syntax
error : identifier 'uintmax_t'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(285) : error C2061: syntax
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C2146: syntax
error : missing ';' before identifier '__gmpfr_mpfr_get_sj'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C4430:
missing
type specifier - int assumed. Note: C++ does not support default-int
missing
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C2146: syntax
error : missing ';' before identifier '__gmpfr_mpfr_get_uj'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C4430:
missing
missing
136>LINK : fatal error LNK1104: cannot open file 'CGAL-vc90-mt-gd.lib'
136>Build log was saved at
"file://c:\CGAL\CGAL-3.5.1\examples\Arrangement_on_surface_2\point_location.dir\Debug\BuildLog.htm"
136>point_location - 1 error(s), 0 warning(s)
at the end I am left with : Rebuild All: 5 succeeded, 435 failed, 4 skipped
can anyone suggest any other installation guide for windows? or can anyone
tell
me what I am doing wrong above?
Many thanks
- [cgal-discuss] installing cgal on windows, f.bazyari, 02/16/2010
- Re: [cgal-discuss] installing cgal on windows, Mohamed Yousef, 02/16/2010
- Re: [cgal-discuss] installing cgal on windows, Laurent Rineau (GeometryFactory), 02/19/2010
