- To:
- Subject: Re: [cgal-discuss] installing cgal on windows
- Date: Fri, 19 Feb 2010 19:14:50 +0100
On Tuesday 16 February 2010 17:37:46
wrote:
> Hello All,
> I am a newbie so hope you don't mind if I ask a primary question.
> I am using windows XP (professional) , visual studio 9.0 and can't get cgal
> installed !!!
> I am following the instructions given here:
> http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on
> -windows
> everything seems to be fine and I can configure/generate using cmake . but
> when I try to make the solution (CGAL.sln) visual studio gives me millions
> of error, most of them are like:
> 137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(280) : error C2061:
> syntax error : identifier 'intmax_t'
Boost-1.42 has a sort of bug that triggers compilation problems within MPFR
when Visual Studio is used. The easiest solution is to downgrade to
Boost-1.41.
Laurent Rineau, PhD
- [cgal-discuss] installing cgal on windows, f.bazyari, 02/16/2010
- Re: [cgal-discuss] installing cgal on windows, Mohamed Yousef, 02/16/2010
- Re: [cgal-discuss] installing cgal on windows, Laurent Rineau (GeometryFactory), 02/19/2010
