cgal-discuss - Re: [cgal-discuss] installing cgal on windows
  • To:
  • Subject: Re: [cgal-discuss] installing cgal on windows
  • Date: Tue, 16 Feb 2010 20:42:17 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=FbmBguM/Vjo3V3TQ7jbbxIaixzKu3nqjDC86dc3smVrzhmMerXOdyIKhrBnVGB2zE8 GKgFl2IABXdGxXhmVFgTnSH8ymLHPKqk/WWa9u5/IgD7O1GWp/xxNzMhX8apSR7NPyAH 030upuBfb/1zZRyHxfnQS+/kz7QebwhIxfjVk=
i can't tell what exactly happened with you , but building CGAL in windows isn't very straight forward
any way i have uploaded binaries for windows , ( compiled using VC++ 2008 express )
here : http://ifile.it/q3hg8sl/CGAL-3.5.rar
(note this is merely the bins , libs , include headers )
hope it helps u an any one struggling with cgal on windows
Regards,
Mohamed Yousef
On 16 February 2010 18:37, <> wrote:
Hello All,
I am a newbie so hope you don't mind if I ask a primary question.
I am using windows XP (professional) , visual studio 9.0 and can't get cgal
installed !!!
I am following the instructions given here:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
everything seems to be fine and I can configure/generate using cmake . but when
I try to make the solution (CGAL.sln) visual studio gives me millions of error,
most of them are like:
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(280) : error C2061: syntax
error : identifier 'intmax_t'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(282) : error C2061: syntax
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(283) : error C2061: syntax
error : identifier 'uintmax_t'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(285) : error C2061: syntax
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C2146: syntax
error : missing ';' before identifier '__gmpfr_mpfr_get_sj'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C4430: missing
type specifier - int assumed. Note: C++ does not support default-int
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C2146: syntax
error : missing ';' before identifier '__gmpfr_mpfr_get_uj'
137>C:\CGAL\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C4430: missing
136>LINK : fatal error LNK1104: cannot open file 'CGAL-vc90-mt-gd.lib'
136>Build log was saved at
"file://c:\CGAL\CGAL-3.5.1\examples\Arrangement_on_surface_2\point_location.dir\Debug\BuildLog.htm"
136>point_location - 1 error(s), 0 warning(s)
at the end I am left with : Rebuild All: 5 succeeded, 435 failed, 4 skipped
can anyone suggest any other installation guide for windows? or can anyone tell
me what I am doing wrong above?
Many thanks
