cgal-discuss - [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • To: cgal-discuss <>
  • Subject: [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • Date: Wed, 17 Feb 2010 19:19:34 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:from:date:x-google-sender-auth:message-id :subject:to:content-type; b=S5hJEYcYsrdUI8ouL8tvZi6svRFI4UhsdDd/5YdJG0969iCt+WtRDlDHu0scA+N0TX mg9vFajc4yM0oLNRREGY8iVz24VDgCGGOMxlfVoxqpaS5ERehP6ZPTzZjGYxR1MFtldl Jc7JWcXHL35Ldx4NPQq1jTPAjD/DCc9g/S0O8=
Hello,
I am trying to install CGAL-3.5.1 on a Windows computer with Visual Studio 2008... and I have some problems doing it.
I have installed every 3rd party component needed, and generated a solution with Cmake from the CGAL directory.
However, when I try to compile it (and the same happens with my own code), I get about 10 error messages for each subcomponent, similar to these:
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(280) : error C2061: syntax error : identifier 'intmax_t'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(282) : error C2061: syntax error : identifier 'intmax_t'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(283) : error C2061: syntax error : identifier 'uintmax_t'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(285) : error C2061: syntax error : identifier 'uintmax_t'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C2146: syntax error : missing ';' before identifier '__gmpfr_mpfr_get_sj'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(286) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C2146: syntax error : missing ';' before identifier '__gmpfr_mpfr_get_uj'
4>C:\CGAL-3.5.1\auxiliary\gmp\include\mpfr.h(287) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
Did any of you have this problem with installation? or knows how to solve it?
Thank you very much for your help!
Best regards,
Jane.
