cgal-discuss - Re: [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • To:
  • Subject: Re: [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • Date: Thu, 18 Feb 2010 14:37:39 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=v9LGzFc9QalPj7jSyuo3bm8aMIUBZANhFtkmMylZYtYCm5vhTPy1RDRHvEq/Z799vI KNgRsLU0dlO9n0qhyLi+rB68MPygVY/OgXFCdvCqxHSzLcCvxDlIW/FbiUkC29zq6brj p0IxjEuyIgu3vlirfMps8oakXG8f4UBnZUKUM=
Sure, I will share the solution if I find it!
Can you please tell us what modification you are making to make it compile? (would be helpful, though temporary!)
Thanks,
Jane.
2010/2/18 Karen Daniels <>
Yes, please do share it with the group.  We are also having this problem with version 3.5.1.
We are temporarily modifying a GMP header file so that we can compile, but this is a temporary patch.  We would like to hear of a more permanent solution that does not disable any GMP types.
     - Karen Daniels
wrote:
Hi Jane,
I (and at least one other person) are having the exact same problem, and
haven't
found a way around it yet.
If you manage to sort it out, would you share the solution here please?
Thanks,
Farhad
Jane.
