cgal-discuss - Re: [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • To:
  • Subject: Re: [cgal-discuss] compiling CGAL with cmake and Visual Studio
  • Date: Thu, 18 Feb 2010 18:08:40 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:content-type; b=R1Wa7UveDpclLxgUxCr+x9tpG+v4QT3hC4b4so6Ux/mXVT4X6xjGNuPlRg0VD52pnQ GddxL/2iC+dL9hlellSvE/cQHWqQC9rfH82wM82E7VxoEqDhmEfRULb336Xf5XMW7g1C x2Z4CyBVowx+tQECU3SpsyFx/cDkbrw6yYXdk=
I finally found the solution :-)
Thanks to this discussion:
http://comments.gmane.org/gmane.comp.lib.mpfr.general/669
and according to the "other problems" section of this page:
http://www.mpfr.org/mpfr-2.4.2/#download
it appears that mpfr and boost versions >= 1.42 are somehow non compatible
I uninstalled boost 1.42.0 and installed boost 1.41.0 instead, and could compile CGAL perfectly well!
Jane.
2010/2/18 Jane Aubert Tournois <>
Sure, I will share the solution if I find it!
Can you please tell us what modification you are making to make it compile? (would be helpful, though temporary!)
Thanks,
Jane.
2010/2/18 Karen Daniels <>
Yes, please do share it with the group.  We are also having this problem with version 3.5.1.
We are temporarily modifying a GMP header file so that we can compile, but this is a temporary patch.  We would like to hear of a more permanent solution that does not disable any GMP types.
     - Karen Daniels
wrote:
Hi Jane,
I (and at least one other person) are having the exact same problem, and
haven't
found a way around it yet.
If you manage to sort it out, would you share the solution here please?
Thanks,
Farhad
Jane.
Jane.
