cgal-discuss - Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
  • To:
  • Subject: Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
  • Date: Fri, 26 Feb 2010 23:48:42 +0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Clw243Z7+aqXHmvV+oQRu3xr9DvVIsGBHLruSAlR3cimvwk7RIckFPIGXrJxj0BSgb ymSHv2XLtMET5iHeJAtqCbqR7TVBrzAU2oWnNXjQwGn2LoKTenWliD7vCAosgS656K+y r+EO5lJeeRCvGK5Eqm54bbReveB7bkqLrLuyc=
copy? I think isnt correctly!
Sorry, I dont known CGAL (MAC).... CPY CGAL *.H into H_dir in your (ENV)
just like stupid idea..
2010/2/26 mangledorf
> It seems CGAL has been using boost's deprecated property_map.hpp file for
> sometime. On my recent install on a MacBook Pro running Mac OS X 10.5 using
> macports to install boost. I found that this deprecated file does not even
> exist so my CGAL program fails to build. I had to copy in the deprecated
> property_map.hpp (which basically just points to
> property_map/property_map.hpp) from a colleagues computer to get CGAL to
> find the correct file.
> Seems this is more a CGAL bug than a macports bug if the file has been long
> deprecated.
> View this message in context:
> http://n4.nabble.com/Deprecated-property-map-hpp-does-not-exist-with-new-macports-boost-tp1571131p1571131.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
