Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
- To:
- Subject: Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
- Date: Fri, 26 Feb 2010 23:51:31 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=HgskIL+qQ/wpwnGf1tGeOUlCiz8fVE5JBwxquUcaiGyjwYWWI66E7IaAMf8oYI5PJ7 KO2hl3pYBmC/xo9iPTSBU56bORTlbsBBeacWcCGVpdAtyBxxEcjsSeJU3AzTSzTaX7mj Y3F58SsiYaZ1iahFqbZ8CJs+t+5FOYY/oEKIU=
boost c++ == hpp?
sorry 4 eng, s3rg.
2010/2/26 S3rG
> copy? I think isnt correctly!
> Sorry, I dont known CGAL (MAC).... CPY CGAL *.H into H_dir in your (ENV)
> just like stupid idea..
> 2010/2/26 mangledorf
>> It seems CGAL has been using boost's deprecated property_map.hpp file for
>> sometime. On my recent install on a MacBook Pro running Mac OS X 10.5 using
>> macports to install boost. I found that this deprecated file does not even
>> exist so my CGAL program fails to build. I had to copy in the deprecated
>> property_map.hpp (which basically just points to
>> property_map/property_map.hpp) from a colleagues computer to get CGAL to
>> find the correct file.
>> Seems this is more a CGAL bug than a macports bug if the file has been long
>> deprecated.
>> View this message in context:
>> http://n4.nabble.com/Deprecated-property-map-hpp-does-not-exist-with-new-macports-boost-tp1571131p1571131.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost, mangledorf, 02/26/2010
- Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost, S3rG, 02/26/2010
