Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
- To:
- Subject: Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost
- Date: Sat, 27 Feb 2010 00:03:35 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=Hn8jphVs9ItH0Xypt6j+AB1IXZ5YyjI1oLdVGGHLh+5frq+5YwXJCKwH37ODWrAQ5g SoSX95snmE4pWdGg4+W+69RZUZQV7wDnL5GzCdCdJM3rZVlQd2V6sxvAfF36/+nJRrLH us3Ch4qm2k/ZfMtrCGbwxKsfLTy4UTmUfQtIE=
I need more *nfos...
Have Q - But just call me =)
8-919-1020501 RUS
lets rock =)
2010/2/26 S3rG
> boost c++ == hpp?
> sorry 4 eng, s3rg.
> 2010/2/26 S3rG
>> copy? I think isnt correctly!
>> Sorry, I dont known CGAL (MAC).... CPY CGAL *.H into H_dir in your (ENV)
>> just like stupid idea..
>> 2010/2/26 mangledorf
>>> It seems CGAL has been using boost's deprecated property_map.hpp file for
>>> sometime. On my recent install on a MacBook Pro running Mac OS X 10.5
>>> using
>>> macports to install boost. I found that this deprecated file does not even
>>> exist so my CGAL program fails to build. I had to copy in the deprecated
>>> property_map.hpp (which basically just points to
>>> property_map/property_map.hpp) from a colleagues computer to get CGAL to
>>> find the correct file.
>>> Seems this is more a CGAL bug than a macports bug if the file has been
>>> long
>>> deprecated.
>>> View this message in context:
>>> http://n4.nabble.com/Deprecated-property-map-hpp-does-not-exist-with-new-macports-boost-tp1571131p1571131.html
>>> Sent from the cgal-discuss mailing list archive at Nabble.com.
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost, mangledorf, 02/26/2010
- Re: [cgal-discuss] Deprecated property_map.hpp does not exist with new macports boost, S3rG, 02/26/2010
