cgal-discuss - Re: [cgal-discuss] using Geomview with CGAL
  • To:
  • Subject: Re: [cgal-discuss] using Geomview with CGAL
  • Date: Sun, 14 Mar 2010 21:42:54 -0700
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=usCWW1UxWj1xAfarNYFoPe8OO5hHqGTy0jSpF8mQYCvCQ8R/UeDE+Ru+r7BFfCx7gA I0D1dIqBJhE6DXUII190GPrLDRM7hs9M3Pe+mnPK+C8RKZg1Wtu1w/Hw0u2CJ14LVWI9 8znEil5HIW/CwBCkXTehp5mSUWusaaHDzqlDQ=
Hi,
Did u  install the CGAL and Geomview in the same compiler environment, i mean  MS9.0 c++ compiler under Windows or GUN C/C++ compiler under Ubuntu/ cygwin ?
best regards
shuchu
On Sun, Mar 14, 2010 at 9:21 AM, <> wrote:
Hi,
I'm pretty sure that the issue about using geomview with CGAL was already asked
before. But recently, i discovered that geomview could be installed on
windows platforms using unix-like systems (portable ubuntu or cygwin...).
To configure CGAL, i tried to fill the variable CGAL_USE_GEOMVIEW in cmake gui
with the path to goemview binaries, but i didn't work out.
Is it correct what i did? is there any additional setting i missed to do?
Any suggestion is helpful.
Best regards,
Youssef ALJ
