cgal-discuss - RE: [cgal-discuss] using Geomview with CGAL
  • To: <>
  • Subject: RE: [cgal-discuss] using Geomview with CGAL
  • Date: Mon, 15 Mar 2010 10:26:34 +0100
  • Importance: Normal
Hi,
Ah no, but here's the answer in your question... ;-)
Actually, i'd like to use Visual studio (so in windows enviroment) with  both cgal and geomview.
Is there any trick to make this feasible?
Best regards,
Youssef ALJ
Date: Sun, 14 Mar 2010 21:42:54 -0700
To:
Subject: Re: [cgal-discuss] using Geomview with CGAL
Hi,
Did u  install the CGAL and Geomview in the same compiler environment, i mean  MS9.0 c++ compiler under Windows or GUN C/C++ compiler under Ubuntu/ cygwin ?
best regards
shuchu
On Sun, Mar 14, 2010 at 9:21 AM, <> wrote:
Hi,
I'm pretty sure that the issue about using geomview with CGAL was already asked
before. But recently, i discovered that geomview could be installed on
windows platforms using unix-like systems (portable ubuntu or cygwin...).
To configure CGAL, i tried to fill the variable CGAL_USE_GEOMVIEW in cmake gui
with the path to goemview binaries, but i didn't work out.
Is it correct what i did? is there any additional setting i missed to do?
Any suggestion is helpful.
Best regards,
Youssef ALJ
Hotmail: Powerful Free email with security by Microsoft. Get it now.
