cgal-discuss - [cgal-discuss] Another Polyhedra question
  • To: CGAL Mailinglist <>
  • Subject: [cgal-discuss] Another Polyhedra question
  • Date: Tue, 16 Mar 2010 11:43:00 +0100 (CET)
  • Organization: Institut fuer Werkstoffe TU Braunschweig
Dear all,
I'm getting a bit desperate while trying to work with Polyhedra-stuff.
The manual says that I can access the plane that belongs to a facet with
Plane_3& f.plane () if Supports_facet_plane == CGAL::Tag_true
However, I do not understand how this really works.
When I create a Polyhedron, e.g., with the make_cube_3-routine that is
provided in the examples, I can access the plane corresponding to each
facet without problems.
However, when I write this Polyhedron to an off-file and read it in
again, I cannot access its planes anymore.
Here is a simple test program to show this:
void do_stuff(Polyhedron & pcube)
for (Halfedge_iterator h=pcube.halfedges_begin(); h !=
pcube.halfedges_end(); ++h)
Facet face=*(h->facet());
std::cout << face.plane().orthogonal_vector() << std::endl;
int main() {
Polyhedron pcube;
make_cube_3(pcube);
std::ofstream os1("poly2.off" ) ;
os1 << pcube ;
os1.close();
do_stuff(pcube);
std::cout << "\n";
Polyhedron pcube2;
std::ifstream is1("poly2.off" ) ;
is1 >> pcube2;
do_stuff(pcube2);
The output for pcube is correct; for pcube2, all orthogonal vectors are
output as 0/1 0/1 0/1.
Is there a way to make sure that I can always access the plane
belonging to a facet? If not, why not? Could I do it by just taking
three points from the facet and create a plane with them?
Any help will be greatly appreciated,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
