cgal-discuss - Re: [cgal-discuss] Another Polyhedra question
  • To:
  • Subject: Re: [cgal-discuss] Another Polyhedra question
  • Date: Tue, 16 Mar 2010 12:36:13 +0100 (CET)
  • Organization: Institut fuer Werkstoffe TU Braunschweig
Sorry, I forgot about the headers (they are pretty standard anyway).
The full program follows after the line:
/// Trying to understand facet planes
#include <CGAL/Gmpq.h>
#include <CGAL/Cartesian.h>
#include <CGAL/Extended_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/intersections.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
#include <iostream>
#include <fstream>
#include <CGAL/Cartesian_converter.h>
#include <stdarg.h>
#include <stdlib.h>
typedef CGAL::Cartesian<CGAL::Gmpq> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Kernel::Plane_3 Plane_3;
typedef Kernel::Point_3 Point;
typedef Kernel::Segment_3 Segment;
typedef Kernel::Vector_3 Vector_3;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
typedef Polyhedron::Facet_handle Facet_handle;
typedef Polyhedron::Facet Facet;
#define pretty(p) " " << ( #p ) << ": " << CGAL::to_double( p.x() ) << " " << CGAL::to_double(
p.y() ) << " " << CGAL::to_double( p.z() )
#define OUT(variable) " " << ( #variable ) << ": " << ( variable )
#define WRITE(variable) std::cout << OUT(variable) << std::endl
const double INVALID=-1.e20;
const double TOLERANCE=1.e-5;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_around_facet_circulator
Halfedge_facet_circulator;
typedef Polyhedron::Halfedge_iterator Halfedge_iterator;
template <class Poly>
typename Poly::Halfedge_handle make_cube_3( Poly& P) {
// appends a cube of size [0,1]^3 to the polyhedron P.
CGAL_precondition( P.is_valid());
typedef typename Poly::Point_3 Point;
typedef typename Poly::Plane_3 Plane;
typedef typename Poly::Halfedge_handle Halfedge_handle;
Halfedge_handle h = P.make_tetrahedron( Point( 1, 0, 0),
Point( 0, 0, 1),
Point( 0, 0, 0),
Point( 0, 1, 0));
Halfedge_handle g = h->next()->opposite()->next();
P.split_edge( h->next());
P.split_edge( g->next());
P.split_edge( g);
h->next()->vertex()->point() = Point( 1, 0, 1);
g->next()->vertex()->point() = Point( 0, 1, 1);
g->opposite()->vertex()->point() = Point( 1, 1, 0);
Halfedge_handle f = P.split_facet( g->next(), g->next()->next()->next());
Halfedge_handle e = P.split_edge( f);
e->vertex()->point() = Point( 1, 1, 1);
P.split_facet( e, f->next()->next());
CGAL_postcondition( P.is_valid());
g = h;
g->facet()->plane() = Plane( g->vertex()->point(),
g->next()->vertex()->point(),
g->next()->next()->vertex()->point());
g = h->opposite();
g = h->next()->opposite();
g = h->next()->next()->opposite();
g = h->next()->next()->next()->opposite();
g = g->next()->next()->opposite();
return h;
void do_stuff(Polyhedron & pcube)
for (Halfedge_iterator h=pcube.halfedges_begin(); h !=
pcube.halfedges_end(); ++h)
Facet face=*(h->facet());
std::cout << face.plane().orthogonal_vector() << std::endl;
int main() {
Polyhedron pcube;
make_cube_3(pcube);
std::ofstream os1("poly2.off" ) ;
os1 << pcube ;
os1.close();
do_stuff(pcube);
std::cout << "\n";
Polyhedron pcube2;
std::ifstream is1("poly2.off" ) ;
is1 >> pcube2;
do_stuff(pcube2);
return 0;
Martin Baeker wrote:
Dear all,
I'm getting a bit desperate while trying to work with Polyhedra-stuff.
The manual says that I can access the plane that belongs to a facet with
Plane_3& f.plane () if Supports_facet_plane == CGAL::Tag_true
However, I do not understand how this really works.
When I create a Polyhedron, e.g., with the make_cube_3-routine that is
provided in the examples, I can access the plane corresponding to each
facet without problems.
However, when I write this Polyhedron to an off-file and read it in
again, I cannot access its planes anymore.
Here is a simple test program to show this:
for (Halfedge_iterator h=pcube.halfedges_begin(); h != pcube.halfedges_end(); ++h)
int main() {
Polyhedron pcube;
make_cube_3(pcube);
os1 << pcube ;
os1.close();
do_stuff(pcube);
std::cout << "\n";
Polyhedron pcube2;
is1 >> pcube2;
do_stuff(pcube2);
The output for pcube is correct; for pcube2, all orthogonal vectors are output as 0/1 0/1 0/1.
Is there a way to make sure that I can always access the plane
belonging to a facet? If not, why not? Could I do it by just taking
three points from the facet and create a plane with them?
Any help will be greatly appreciated,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
e-mail
Can you please post the typedefs as well, so as to make your example compilable.
S.
Langer Kamp 8
38106 Braunschweig
Germany
e-mail
