- To:
- Subject: Re: [cgal-discuss] Assessing the facet of a halfedge in a nef-polyhedron
- Date: Tue, 16 Mar 2010 12:43:10 +0100 (CET)
- Organization: Institut fuer Werkstoffe TU Braunschweig
when I create a Nef-Polyhedron, I can easily iterate over all its
(half)edges like this: (The Nef_polyhedron is called Cube here)
for(Nef_polyhedron::Halfedge_const_iterator
e = Cube.halfedges_begin(),
end = Cube.halfedges_end();
e != end; ++e)
// do stuff
Is there a way to get at the facet(s) that are bordered by e?
I guess the function incident_sface described here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3-Traits---Halfedge.html#Function_SFace_const_handle_incident_sface69_const;
should do the job.
thanks for the quick answer, but this function gives me an SFace - I
do not see how I can access the facet that belongs to this SFace (what
I actually need is an orthogonal vector on this facet).
The
spherical-map concept allows to adress SFaces, but these seem not to
be identical to the facets of the polyhedron - I have to admit that
I'm a bit confused by the spherical-map concept...
Thanks again for any help,
Martin.
Priv.-Doz. Dr. Martin Bäker
Institut für Werkstoffe
Technische Universität Braunschweig
Langer Kamp 8
38106 Braunschweig
Germany
Tel.: 00-49-531-391-3073
Fax 00-49-531-391-3058
- [cgal-discuss] Assessing the facet of a halfedge in a nef-polyhedron, Martin Baeker, 03/16/2010
- Re: [cgal-discuss] Assessing the facet of a halfedge in a nef-polyhedron, Sebastien Loriot (GeometryFactory), 03/16/2010
- Re: [cgal-discuss] Assessing the facet of a halfedge in a nef-polyhedron, Martin Baeker, 03/16/2010
