cgal-discuss - [cgal-discuss] "cannot convert parameter from" error in CGAL
  • To:
  • Subject: [cgal-discuss] "cannot convert parameter from" error in CGAL
  • Date: Wed, 17 Mar 2010 12:38:26 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=ZG3zA65ORWSrYXTHJF8CQFJdO9qDlXu9k6hG0F43JjaOF4pORA/S0nD2aR24NQgBax LUb84FHfFxLNcmeUTG/fBQ/QxxqEKwx6WIX/DzB26Hu03D3417gwXksgRPkF4AZaRcdI MpFPl7IGeri0r/Hl7VJCsJtB72nhRJZH9RLlk=
>g:\projects\ts\cgal\cgal\arrangement_2\arrangement_on_surface_2_impl.h(3229)
>: error C2664:
>'CGAL::Arrangement_on_surface_2<GeomTraits_,TopTraits_>::_notify_before_modify_edge'
> : cannot convert parameter 1 from
>'CGAL::I_Filtered_iterator<Iterator_,Filter_,Value_,Diff_,Category_>
>(__cdecl *)(void)' to
>'CGAL::I_Filtered_iterator<Iterator_,Filter_,Value_,Diff_,Category_>'
Of course the error gets longer than this (ridiculously longer) but at
some place it points to the instantiation of
CGAL::Polygon_set_2< K, std::list<K::Point2> > in my code.
where:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
The compiler is Visual C++ 2008.
What's even more mysterious - I can instantiate CGAL::Polygon_set_2
with the same template parameters in another project without any
errors.
