cgal-discuss - [cgal-discuss] Re: Segfault when customizing Point class used in triangulation
  • To:
  • Subject: [cgal-discuss] Re: Segfault when customizing Point class used in triangulation
  • Date: Fri, 19 Mar 2010 05:22:24 -0800 (PST)
Beginning and end of backtrace (gdb output):
#0 0x00000000004404e7 in CGAL::Sign
CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Gmpq>
>, CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cart
esian<CGAL::Interval_nt<false> > >,
CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,
CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >, CGAL::Filter
CGAL::Simple_cartesian<CGAL::Gmpq>, CGAL::NT_converter<double, CGAL::Gmpq>
ref_count<double, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>,
true> >, CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >,
CGAL::Simple_cartesian<CGAL::Interval_nt<false> >, CGAL::NT_con
verter<double, CGAL::Interval_nt<false> > >,
true>::operator()<MyPoint<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>,
>(MyPoint<CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>,
Simple_cartesian<double>, true> > const&,
const&, MyPoint<CG
AL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> >,
CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>, true> > const&) const
#1 0x000000000044774e in CGAL::Triangulation_2<MyKernel,
CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<MyKernel,
CGAL::Triangulation_ds_vertex_base_2<void> >, CGAL::Constrained_tria
ngulation_face_base_2<MyKernel, CGAL::Triangulation_face_base_2<MyKernel,
CGAL::Triangulation_ds_face_base_2<void> > > >
>::includes_edge(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulati
CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<MyKernel,
d_triangulation_face_base_2<MyKernel,
CGAL::Triangulation_ds_face_base_2<void> > > > > >, CGAL::Default>, false>,
---Type <return> to continue, or q <return> to quit---
, CGAL::Constrained_triangulation_face_base_2<MyKernel,
:Compact_container<CGAL::Triangulation_vertex_base_2<MyKernel,
tex_base_2<void> >, CGAL::Constrained_triangulation_face_base_2<MyKernel,
CGAL::Triangulation_ds_face_base_2<void> > > > > >, CGAL::Default>, false>&,
CGAL::internal
::CC_iterator<CGAL::Compact_container<CGAL::Constrained_triangulation_face_base_2<MyKernel,
CGAL::Triangulation_ds_face_base_2<CGAL::Triangulation_data_structure_2<C
CGAL::Triangulation_face_base_2<MyKernel, CGAL::Triangulation_ds
_face_base_2<void> > > > > > >, CGAL::Default>, false>&, int&) const ()
#2 0x000000000044a1b1 in CGAL::Constrained_triangulation_2<MyKernel,
CGAL::Triangulation_ds_face_base_2<void> > > >,
CGAL::Exact_predicates_tag>::insert_constraint(CGAL::internal::CC_iterato
r<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<MyKernel,
CGAL::Triangulation
CGAL::in
ternal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<MyKernel,
C
, false>) ()
#3 0x00000000004556a1 in CGAL::Constrained_triangulation_2<MyKernel,
CGAL::Exact_predicates_tag>::intersect(CGAL::internal::CC_iterator<CGAL::
CGAL::Triangulation_ds_face_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_v
ertex_base_2<MyKernel, CGAL::Triangulation_ds_vertex_base_2<void> >,
> > > > >, CGAL::Default>, false>, int,
CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<MyKernel,
CGAL::Exact_predicates_tag) ()
#4 0x0000000000455898 in CGAL::Constrained_triangulation_2<MyKernel,
#26189 0x000000000044a469 in CGAL::Constrained_triangulation_2<MyKernel,
CGAL::Triangulat
CGAL:
CGAL::Triangulation_ds_face_base_2<void> > > > > >, CGAL::Default>, false>)
#26190 0x000000000044a469 in CGAL::Constrained_triangulation_2<MyKernel,
CGAL::Triangulat
CGAL:
#26191 0x000000000044a469 in CGAL::Constrained_triangulation_2<MyKernel,
CGAL::Triangulat
CGAL:
lt>, false>) ()
#26192 0x0000000000437b8c in main ()
View this message in context:
http://n4.nabble.com/Segfault-when-customizing-Point-class-used-in-triangulation-tp1598397p1599336.html
