- To:
- Subject: [cgal-discuss] Segfault when customizing Point class used in triangulation
- Date: Thu, 18 Mar 2010 10:11:35 -0800 (PST)
I would like to use a custom Point class with the CGAL constrained delaunay
triangulation. However, with the following MyPoint class (which should
behave the exact same as a CGAL::Point_2 no?) I get segmentation faults
inside insert_constraint (with a backtrace of several thousands of function
calls). It works perfectly if I set the Point_2 typedef inside MyKernel to
CGAL::Exact_predicates_inexact_constructions_kernel::Point_2. What am I
doing wrong?
template<class P>
struct MyPoint : public P {
MyPoint() : P() {}
MyPoint(const MyPoint& p) : P(p) {}
MyPoint( int x, int y) : P(x,y) {}
MyPoint( double x, double y) : P(x,y) {}
struct MyKernel : CGAL::Exact_predicates_inexact_constructions_kernel {
typedef
MyPoint<CGAL::Exact_predicates_inexact_constructions_kernel::Point_2>
Point_2;
typedef MyKernel K;
typedef CGAL::Triangulation_vertex_base_2<K> Vb;
typedef CGAL::Constrained_triangulation_face_base_2<K> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> TDS;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, Itag> CDT;
typedef CDT::Point Point;
CDT cdt;
Point cgal_p1;
Point cgal_p2;
cgal_p1 = Point(p1[1],p1[2]);
cgal_p2 = Point(p2[1],p2[2]);
cdt.insert_constraint(cgal_p1,
cgal_p2);
View this message in context:
http://n4.nabble.com/Segfault-when-customizing-Point-class-used-in-triangulation-tp1598397p1598397.html
- [cgal-discuss] Segfault when customizing Point class used in triangulation, MHOOO, 03/18/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Ramin H, 03/18/2010
- [cgal-discuss] Re: Segfault when customizing Point class used in triangulation, MHOOO, 03/19/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Laurent Rineau (GeometryFactory), 03/19/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Laurent Rineau (GeometryFactory), 03/18/2010
- How to derive from a CGAL kernel (was Re: [cgal-discuss] Segfault when customizing Point class used in triangulation), Laurent Rineau (GeometryFactory), 03/26/2010
