- To:
- Subject: Re: [cgal-discuss] Segfault when customizing Point class used in triangulation
- Date: Fri, 19 Mar 2010 14:26:50 +0100
On Thursday 18 March 2010 20:10:13 Ramin H wrote:
> I believe CGAL's triangulation data structure uses weighted points.
CGAL triangulation data structures do not use points at all, but only
vertices. Exactly it uses objects whose class must be a model of the
following
concept:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDataStructure_2--
Vertex.html
Optionally, there can be a Point type in that Vertex concept. For Delaunay
triangulation, that point type can be a regular Kernel::Point_2 type. For
*regular* triangulations, them the point type is required to be a weighted
point type.
Laurent Rineau, PhD
- [cgal-discuss] Segfault when customizing Point class used in triangulation, MHOOO, 03/18/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Ramin H, 03/18/2010
- [cgal-discuss] Re: Segfault when customizing Point class used in triangulation, MHOOO, 03/19/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Laurent Rineau (GeometryFactory), 03/19/2010
- Re: [cgal-discuss] Segfault when customizing Point class used in triangulation, Laurent Rineau (GeometryFactory), 03/18/2010
- How to derive from a CGAL kernel (was Re: [cgal-discuss] Segfault when customizing Point class used in triangulation), Laurent Rineau (GeometryFactory), 03/26/2010
