cgal-discuss - Re: [cgal-discuss] Dealing with Precision and Speed
  • To:
  • Subject: Re: [cgal-discuss] Dealing with Precision and Speed
  • Date: Fri, 19 Mar 2010 15:51:41 +0100
Hi Karl,
As Ben pointed out, iterative algorithms are nothing you should
run with an exact constructions kernel.
You say that you rotate something in order to get it into the 2D
plane, run a 2D algorithm and then rotate it back.
Sometimes it is possible to avoid that and run the 2D algorithm
directly in the slanted plane.
For one commercial customer we developed a 2D Delaunay triangulation
for points on a slanted plane, that instead of in-circle predicates
uses in-sphere predicates. In this way it works on the 3D input
without any transformation going on. Maybe something similar
might work for your application.
Concerning GMP, it is not part of CGAL, but a third-party library
distributed under the LGPL, that is, it can be used freely in
commercial applications.
best regards,
andreas
On 19/03/2010 15:26, Karl Gaize wrote:
thanks for the input Ben, let me just throw a few things back at you
though....
I've tried using a filtered kernel and couldn't find any difference in
its working, my algorithm failed the same way, at the same point as it
did with the non-filtered kernel.
I've looked at the exact predicates inexact constructions kernel, and I
don't think that it would help in this case, the main problem being that
I'm inherently working with constructed
geometry, as I have to do a couple of affine transformations to get the
geometry from its original 3d into the XY plane for my algorithm to work.
I can't use GMP unless I can get a commercial license for it, which we
have for CGAL, but due to limited finances, we only have licenses for
the CGAL core and HalfedgeDS data structures.
this also means we can't use the polygon and polyhedron operations,
arrangements or anything like that.
It's definitely the "infinite" mantissas that are causing me the
problems in an exact kernel though, as an inspection of the data
structures reveals mantissa lengths of anywhere upwards of 50,000
entries. This is primarily caused by, as you say, my algorithm being
highly constructive. I'll have a look through to see if there are any
natural breakpoints where I can apply an approximation rounding before
carrying on, but my feeling is that even between the rounding steps, my
mantissas are going to go through the roof as I need to use a *lot* of
line/line intersections to generate new vertices within the mesh.
your point about leveraging the other CGAL algorithms is a good one, but
again I'm limited by our license and whatever functionality I can bolt
on top of it
Karl
On 19/03/2010 13:47, Ben Supnik wrote:
Hi Karl,
One or two thoughts from my own experience on speed. Basic stuff:
- Fundamentally an infinite precision operation is going to be a lot
more expensive than floating point.
- The various filtering and lazy kernels _do_ help a lot. They're all
adapters that defer the cost of the heavy op until it is really needed.
- Depending on your algorithm can you use an exact predicates, inexact
constructions kernel? Only part of CGAL will tolerate this, but it is a
lot faster than exact constructions.
- You might want to try GIMP instead of MP_float...when I tested both,
GIMP was faster, although not by astoundingly large margins.
More subtle:
- If you can accept rounding error in your app, and you can identify
points where you can round without breaking CGAL, "truncating" your CGAL
results before they go back into CGAL can be a big speed win.
The issue is that CGAL is going to build up longer and longer mantissas
as it continues to construct exact geometry. If you are doing a highly
constructive algorithm (like inserting all sorts of derived segments
into an arrangement) the new points that you are "building" may have
very long mantissas due to the way the math works out.
CGAL will never simplify them, and your calculations become
proportionally more expensive. If you know you don't need that kind of
precision AND you can find a step where you can round without breaking a
CGAL assumption, building a new CGAL structure off of th approximation
of the old one will help.
(In my code I was building an inset polygon out of the faces of an
arrangement. Since the arrangement is already the intersection of many
lines, most of its "discovered" vertices are going to have long
mantissas. The inset/buffer operation was thus being run on very
expensive exact input data. Since my buffer code could handle degenerate
polygons and other ugly cases, I simply took my input faces, rounded
their contours to double, and then work on those. The resulting inset
operation was _much_ faster.)
- I have found CGAL's speed to be very good, but in my own conversion to
CGAL from my own proprietary floating point code, it has taken a while
to discover that speed. The reason is that CGAL is very strong
_algorithmically_ whereas my code tended to be very constructive. As I
stepped back and replaced whole algorithms with superior CGAL versions I
ended up getting more work out of the computer in less time, but the
first "direct" port was fairly unusable.
For example, my old arrangement code could do some copy and insert
operations faster than CGAL (because the underlying calculation was
double - a CGAL arrangement based on cartesian double would probably
have been just as fast as mine, were that a legal instantiation).
But CGAL has sweep-based algorithms that let you do things like
whole-arrangement merges very efficiently. As I started leveraging these
wider algorithms, whole chunks of slow code were replaced by something
with a better O(N).
Anyway, hope that helps.
cheers
ben
Vicomt wrote:
OK, so I have a problem, a couple of problems in fact.
The current project I'm working on works as a plugin DLL within another
application, this other application is a double based CAD engine, it has
it's won problems with precision which it gets round by using
tolerances.
I wanted to go away from toleranced or inherently inaccurate geometry,
so I
started off using the exact_predicates_exact_construction kernel
based on
the internal MP_Float type. thisngs seems to go well until I started
noticing some serious problems with speed, not 25% or even 50% slower,
these
algorithms seemed to run considerably slower, somwhere in the region of
10-20 times the amount of time taken. so I gave up for a while. I
dropped
back to using a cartesian<double> kernel and started building my own
methods
with would allow me to use tolerances when I needed them.
I got everything working - success, or so I thought, until I realised I
wasn't correctly handling certain geometrical cases, to fix this I
had to
introduce a couple of transformations (rotation around an axis) to
get my
geometry in a known format before I processed the algorithm. That's
when it
all fell apart.
with a double precision kernel, rotating a facet a couple of times, then
modifying that facet, and rotating back to my original coordinate space
introduced errors. errors big enough for various CGAL functions to stop
working - like plane_3::has_on() which returns false when my point is
literally 1exp-15 units away from the plane.
so I went back to an exact kernel again, and I'm still sat here over
an hour
after I started the run. when the double kernel runs in approximately 2
tenths of a second.
I'm confused. Is there something I could be doing which results in
MP_Float
based calculations being thousands of times slower? is there any way I
can
make CGAL tolerant of tiny distances in case there's nothing I can do
with
the complex numbers?
I hope someone can send some enlightenment my way.
Karl
