- To:
- Subject: Re: [cgal-discuss] Dealing with Precision and Speed
- Date: Fri, 19 Mar 2010 09:47:16 -0400
Hi Karl,
One or two thoughts from my own experience on speed. Basic stuff:
- Fundamentally an infinite precision operation is going to be a lot more expensive than floating point.
- The various filtering and lazy kernels _do_ help a lot. They're all adapters that defer the cost of the heavy op until it is really needed.
- Depending on your algorithm can you use an exact predicates, inexact constructions kernel? Only part of CGAL will tolerate this, but it is a lot faster than exact constructions.
- You might want to try GIMP instead of MP_float...when I tested both, GIMP was faster, although not by astoundingly large margins.
More subtle:
- If you can accept rounding error in your app, and you can identify points where you can round without breaking CGAL, "truncating" your CGAL results before they go back into CGAL can be a big speed win.
The issue is that CGAL is going to build up longer and longer mantissas as it continues to construct exact geometry. If you are doing a highly constructive algorithm (like inserting all sorts of derived segments into an arrangement) the new points that you are "building" may have very long mantissas due to the way the math works out.
CGAL will never simplify them, and your calculations become proportionally more expensive. If you know you don't need that kind of precision AND you can find a step where you can round without breaking a CGAL assumption, building a new CGAL structure off of th approximation of the old one will help.
(In my code I was building an inset polygon out of the faces of an arrangement. Since the arrangement is already the intersection of many lines, most of its "discovered" vertices are going to have long mantissas. The inset/buffer operation was thus being run on very expensive exact input data. Since my buffer code could handle degenerate polygons and other ugly cases, I simply took my input faces, rounded their contours to double, and then work on those. The resulting inset operation was _much_ faster.)
- I have found CGAL's speed to be very good, but in my own conversion to CGAL from my own proprietary floating point code, it has taken a while to discover that speed. The reason is that CGAL is very strong _algorithmically_ whereas my code tended to be very constructive. As I stepped back and replaced whole algorithms with superior CGAL versions I ended up getting more work out of the computer in less time, but the first "direct" port was fairly unusable.
For example, my old arrangement code could do some copy and insert operations faster than CGAL (because the underlying calculation was double - a CGAL arrangement based on cartesian double would probably have been just as fast as mine, were that a legal instantiation).
But CGAL has sweep-based algorithms that let you do things like whole-arrangement merges very efficiently. As I started leveraging these wider algorithms, whole chunks of slow code were replaced by something with a better O(N).
Anyway, hope that helps.
cheers
ben
Vicomt wrote:
OK, so I have a problem, a couple of problems in fact.
The current project I'm working on works as a plugin DLL within another
application, this other application is a double based CAD engine, it has
it's won problems with precision which it gets round by using tolerances.
I wanted to go away from toleranced or inherently inaccurate geometry, so I
started off using the exact_predicates_exact_construction kernel based on
the internal MP_Float type. thisngs seems to go well until I started
noticing some serious problems with speed, not 25% or even 50% slower, these
algorithms seemed to run considerably slower, somwhere in the region of
10-20 times the amount of time taken. so I gave up for a while. I dropped
back to using a cartesian<double> kernel and started building my own methods
with would allow me to use tolerances when I needed them.
I got everything working - success, or so I thought, until I realised I
wasn't correctly handling certain geometrical cases, to fix this I had to
introduce a couple of transformations (rotation around an axis) to get my
geometry in a known format before I processed the algorithm. That's when it
all fell apart.
with a double precision kernel, rotating a facet a couple of times, then
modifying that facet, and rotating back to my original coordinate space
introduced errors. errors big enough for various CGAL functions to stop
working - like plane_3::has_on() which returns false when my point is
literally 1exp-15 units away from the plane.
so I went back to an exact kernel again, and I'm still sat here over an hour
after I started the run. when the double kernel runs in approximately 2
tenths of a second.
I'm confused. Is there something I could be doing which results in MP_Float
based calculations being thousands of times slower? is there any way I can
make CGAL tolerant of tiny distances in case there's nothing I can do with
the complex numbers?
I hope someone can send some enlightenment my way.
Karl
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Dealing with Precision and Speed, Vicomt, 03/19/2010
- Re: [cgal-discuss] Dealing with Precision and Speed, Ben Supnik, 03/19/2010
- Re: [cgal-discuss] Dealing with Precision and Speed, Karl Gaize, 03/19/2010
- Re: [cgal-discuss] Dealing with Precision and Speed, Andreas Fabri, 03/19/2010
- Re: [cgal-discuss] Dealing with Precision and Speed, Bernd Gaertner, 03/19/2010
