cgal-discuss - Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • To:
  • Subject: Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • Date: Mon, 22 Mar 2010 20:59:56 +0100
Le Lundi 22 Mars 2010 19:46:41, Edoardo Milotti a écrit :
> I use CMake 2.8.0, Boost 1.42.0 (installed with MacPorts on MacOS X
> 10.6.2), and I just installed CGAL 3.6. It seems that BOOST_VERSION is not
> properly set by CMake, although CMake detects the correct Boost version.
> This is part of the CMake output:
> -- Boost version: 1.42.0
> -- Found the following Boost libraries:
> -- thread
> -- Boost include: /opt/local/include
> -- Boost libraries:
> optimized;/opt/local/lib/libboost_thread-mt.dylib;debug;/opt/local/lib/lib
> boost_thread-mt-d.dylib -- Boost definitions:
> -- USING BOOST_VERSION = '1.42.0'
> The compile phase went smoothly and then I compiled the examples with "make
> examples". Here the procedure halted because it could not find
> boost/property_map.hpp. However the header files contain the preprocessor
> statements
> #if BOOST_VERSION >= 104000
> #include <boost/property_map/property_map.hpp>
> #else
> #include <boost/property_map.hpp>
> #endif
> and <boost/property_map/property_map.hpp> does exist in my installation. So
> I commented out part of the preprocessor code
> //#if BOOST_VERSION >= 104000
> //#else
> //#include <boost/property_map.hpp>
> //#endif
> wherever needed, and this fixed the problem.
I agree there could be a compilation problem in CGAL with Boost-1.42.
Which files have you modified?
Laurent Rineau, PhD
