cgal-discuss - Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • To:
  • Subject: Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • Date: Tue, 23 Mar 2010 14:25:37 +0100
Hi Edoardo.
You are using the Intel C++ Compiler, aren't you? That compiler is not yet
fully supported by CGAL, wheras we test it daily.
On Tuesday 23 March 2010 14:06:09 Edoardo Milotti wrote:
> ld: warning: duplicate dylib /opt/local/lib/libboost_thread-mt.dylib
That is a linker warning: it says that some libraries are passed as argument
more than once in the linker command line. We know that issue, but we have
not
yet invest much time to find a solution.
> [ 52%] Building CXX object
> examples/Modular_arithmetic/CMakeFiles/modular_filter.dir/modular_filter.o
> /CG_Software/CGAL-3.6/CGAL-3.6/examples/Modular_arithmetic/../../include/C
> GAL/number_utils.h(133): error: call of an object of a class type without
> appropriate operator() or conversion functions to pointer-to-function type
> return gcd( x, y );
Intel Compiler lookup problem. Nobody has tried yet to find a workaround.
> [ 61%] Building CXX object
> examples/Surface_mesh_parameterization/CMakeFiles/Taucs_parameterization.d
> ir/Taucs_parameterization.o /usr/local/include/taucs.h(814): error: more
> than one instance of overloaded function "isnan" has "C" linkage extern
> int isnan(double);
> /usr/local/include/taucs.h(820): error: more than one instance of
> overloaded function "isinf" has "C" linkage extern int isinf(double);
That is a bug of TAUCS. Taucs is an external library to CGAL. We have tried
out best to support it for a while, but that library support will probably be
dropped by CGAL one day or another.
If you have a cross-platform patch for that issue, we will merge it in our
repository.
> /CG_Software/CGAL-3.6/CGAL-3.6/examples/Surface_reconstruction_points_3/poi
> sson_reconstruction.cpp(29): catastrophic error: could not open source file
> "CGAL/ARAP/mkl_solver_traits.h" #include <CGAL/ARAP/mkl_solver_traits.h>
That is a bug. As you can see, someone has commited a temporary change to
that
package, and let it goes to the release branch. :-(
Surface_reconstruction_points_3 is not yet ready to be used with MKL.
Laurent Rineau, PhD
