cgal-discuss - Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • To:
  • Subject: Re: [cgal-discuss] incorrectly set BOOST_VERSION
  • Date: Tue, 23 Mar 2010 14:33:43 +0100
yes, I'm using the Intel compiler. I have not tried the GNU compiler, since
it takes quite a while to compile al the examples.
Thank you.
Best wishes,
Edoardo
On 23/mar/2010, at 14.25, Laurent Rineau (GeometryFactory) wrote:
> Hi Edoardo.
> You are using the Intel C++ Compiler, aren't you? That compiler is not yet
> fully supported by CGAL, wheras we test it daily.
> On Tuesday 23 March 2010 14:06:09 Edoardo Milotti wrote:
>> ld: warning: duplicate dylib /opt/local/lib/libboost_thread-mt.dylib
> That is a linker warning: it says that some libraries are passed as
> argument
> more than once in the linker command line. We know that issue, but we have
> not
> yet invest much time to find a solution.
>> [ 52%] Building CXX object
>> examples/Modular_arithmetic/CMakeFiles/modular_filter.dir/modular_filter.o
>> /CG_Software/CGAL-3.6/CGAL-3.6/examples/Modular_arithmetic/../../include/C
>> GAL/number_utils.h(133): error: call of an object of a class type without
>> appropriate operator() or conversion functions to pointer-to-function type
>> return gcd( x, y );
> Intel Compiler lookup problem. Nobody has tried yet to find a workaround.
>> [ 61%] Building CXX object
>> examples/Surface_mesh_parameterization/CMakeFiles/Taucs_parameterization.d
>> ir/Taucs_parameterization.o /usr/local/include/taucs.h(814): error: more
>> than one instance of overloaded function "isnan" has "C" linkage extern
>> int isnan(double);
>> /usr/local/include/taucs.h(820): error: more than one instance of
>> overloaded function "isinf" has "C" linkage extern int isinf(double);
> That is a bug of TAUCS. Taucs is an external library to CGAL. We have tried
> out best to support it for a while, but that library support will probably
> be
> dropped by CGAL one day or another.
> If you have a cross-platform patch for that issue, we will merge it in our
> repository.
>> /CG_Software/CGAL-3.6/CGAL-3.6/examples/Surface_reconstruction_points_3/poi
>> sson_reconstruction.cpp(29): catastrophic error: could not open source file
>> "CGAL/ARAP/mkl_solver_traits.h" #include <CGAL/ARAP/mkl_solver_traits.h>
> That is a bug. As you can see, someone has commited a temporary change to
> that
> package, and let it goes to the release branch. :-(
> Surface_reconstruction_points_3 is not yet ready to be used with MKL.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
