- To:
- Subject: Re: [cgal-discuss] Re: outer boundary with degenerate polygons
- Date: Tue, 23 Mar 2010 16:20:42 +0200
If, for example, you enter a degenerate polygon that has 0 area into an arrangement, then the number of faces of the arrangement does not change.
In your case you may need to do much more than that - you may need to repair your polygons. This is an entire different subject though.
Quoting Obergude
okay, but how can i test whether they are not degenerate with an arrangement?
i'm sorry, but this is the first time i'm working with cgal.
regards
Obergude
View this message in context: http://n4.nabble.com/outer-boundary-with-degenerate-polygons-tp1593029p1594503.html
- [cgal-discuss] outer boundary with degenerate polygons, Obergude, 03/15/2010
- Re: [cgal-discuss] outer boundary with degenerate polygons, Efraim Fogel, 03/15/2010
- [cgal-discuss] Re: outer boundary with degenerate polygons, Obergude, 03/16/2010
- Re: [cgal-discuss] Re: outer boundary with degenerate polygons, efif, 03/23/2010
