cgal-discuss - [cgal-discuss] outer boundary with degenerate polygons
  • To:
  • Subject: [cgal-discuss] outer boundary with degenerate polygons
  • Date: Sun, 14 Mar 2010 23:45:43 -0800 (PST)
Hi guys,
i am really new to CGAL and i have some problems with it. So here it is:
I am trying to get the maximal outer boundary of a 3d-house-model and using:
vector<Polygon_2> polygonList;
Polygon_set_2 S;
for(int i = 0; i<polygonCounter; i++){
S.join (polygonListe[i]);
to generate the outer boundary.
For the outer boundary of the house, i don't need to store the z-coordinate
of the polygon-vertices - only need to get a 2d-stamp of the house.
So i just create some "Polygon_2 p (Point_2(x,y))" and store the
x-y-coordinate. The problem is that i get some degenerated polygons because
of some vertical polygons in my 3d-model - like the walls of the house. The
vertices are like: Point_2(0,0), Point_2(1,0), Point_2(1,0), Point_2(0,0).
The problem is, that i get this error when a start the application:
CGAL error: precondition violation!
Expression: ! is_degen
File: \cgal-3.5.1\include\cgal\arr_segment_traits_2.h
Line: 125
because of the degenerate polygons.
So how can i test, if a polygon is degenerated? Or superiorly - how can i
get the outer boundary with a degeneratet polygon (like a wall (without
size) that is not under a roof).
I am really sorry about my bad english and i hope you get what i mean.
Thank you for help.
Cheers Obergude
View this message in context:
http://n4.nabble.com/outer-boundary-with-degenerate-polygons-tp1593029p1593029.html
