cgal-discuss - Re: [cgal-discuss] From Plane_3 to Surface_3
  • To:
  • Subject: Re: [cgal-discuss] From Plane_3 to Surface_3
  • Date: Wed, 24 Mar 2010 12:01:45 +0200
Quoting "Samer Afach"
But I've seen in the envelope program that it already supports triangles
just like it supports planes with two different examples with similar
outputs, isn't this the case? what's the difference between the
implementation of triangles or planes equations? and I went through the
functions in the reference manual in that class and couldn't find the
function I need. Could you please tell me what's the name of that
function if you know it?
CGAL::lower_envelope_3() ???
I believe that the lower envelope of planes will not get you the desired answer. Again, unless I misunderstand your problem.
Thank you,
Samer
wrote:
One way to do it is to triangulate the polyhedron facets (in case they
are not triangles to start with) and then compute the envelope of all
triangles. Consult the manual for further information. There are also
examples you can use as a starting point.
Exactly! That's what I'm looking for actually! But could you please tell
me how to implement it? does the envelope class have such a function?
Thank you,
Samer
wrote:
If you are looking for a function that accepts a polyhedron and a
point in the plane and returns the point on the lower envelope of the
polyhedron, the vertical projection of which coincides with the input
point, then you can implement it using the existing functionality.
Otherwise, I don't understand your question.
Thank you for your reply.
Actually I'm concerned now before this with the question whether the
envelope algorithm offers the envelope as a function and not surfaces,
because I couldn't find a single function in the corresponding class
that does that. Does it do that? I mean I would like to give it a
polyhedron, and on the other side using minimum and maximum get the
envelopes as functions of x and y, is that possible?
I'd appreciate any efforts so much,
Thank you,
Samer
wrote:
You need to use an exact-predicate and exact-construction kernel. If
you do that and the problem still occurs, please send the entire
(small) program that reproduces the problem.
Quoting
Hello,
I eventually have found that the planes are being taken in the
right way
by dereferencing the iterator, but the program is failing in giving
the
right envelope, and giving an unexplainable exception, I started to
believe that the algorithm has a problem... here's the part of the
code,
where P is a closed polyhedron object
for(plane_it = P.planes_begin(); plane_it !=
P.planes_end();++plane_it)
planes.push_back(Surface_3(*plane_it));
cout<<*plane_it<<endl;
//this is a part where the example inserted the points
planes.push_back (Surface_3(Plane_3(-1, 0, 1, 0)));
planes.push_back (Surface_3(Plane_3(0, 1 , 1, 0)));
planes.push_back (Surface_3(Plane_3(1, 0, 1, 0)));
// Compute and print the minimization diagram.
Envelope_diagram_2 min_diag;
CGAL::lower_envelope_3 (planes.begin(), planes.end(), min_diag);
std::cout << std::endl << "The minimization diagram:" <<
std::endl;
print_diagram (min_diag);
// Compute and print the maximization diagram.
Envelope_diagram_2 max_diag;
CGAL::upper_envelope_3 (planes.begin(), planes.end(), max_diag);
std::cout << std::endl << "The maximization diagram:" <<
std::endl;
print_diagram (max_diag);
The polyhedron I'm using has like 30 facets or more, and is
closed and
follow the Euler characteristic, and I could view it using
Geomview. So
I'm very confused and don't know where the error could be. The
exception
differs everytime because I'm every time generating a new polyhedron
that
fulfills the conditions mention. here's the error I'm getting in
Terminal:
terminate called after throwing an instance of
'CGAL::Precondition_exception'
what(): CGAL ERROR: precondition violation!
Expr: cv.has_left()
File: /usr/local/include/CGAL/Arr_linear_traits_2.h
Line: 682
Aborted
and here's another one too:
Expr: f == f2
File:
/usr/local/include/CGAL/Arrangement_2/Arrangement_on_surface_2_impl.h
Line: 2639
Explanation: The two halfedges must share the same incident face.
Aborted
This last error I can't understand, what does the envelope thing
have to
do with the halfedges? I'm giving the program plane equations and
it has
nothing to do with my polyhedron.
Any effort is highly appreciated,
Thank you,
Samer Afach
Hello programmers,
I have a question since I'm not a professional C++ programmer. I'm
trying to apply the 3D envelope example 32.3.3 in
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Envelope_3/Chapter_main.html
but I'm taking the planes from a polyhedron, and I have them in the
type
Plane_3 through the iterator Polyhedron::begin() to end(). The
example
takes them in the form Surface_3(Plane_3()), how can I do this
transformation? I tried to use std::transform for this but I
failed.
The example provides it using the 4 coefficients of a plane, I can
see
these coefficients of my Plane_3 object on a cout stream, but I
can't
extract them alone one by one.
Could you please either tell me the correct transformation
method for
this or tell me how to extract the coefficients from my Plane_3
object?
Thank you,
Samer Afach
