cgal-discuss - Re: [cgal-discuss] From Plane_3 to Surface_3
  • To:
  • Subject: Re: [cgal-discuss] From Plane_3 to Surface_3
  • Date: Wed, 24 Mar 2010 10:35:08 +0100
Exactly! That's what I'm looking for actually! But could you please tell
me how to implement it? does the envelope class have such a function?
Thank you,
Samer
wrote:
> If you are looking for a function that accepts a polyhedron and a
> point in the plane and returns the point on the lower envelope of the
> polyhedron, the vertical projection of which coincides with the input
> point, then you can implement it using the existing functionality.
> Otherwise, I don't understand your question.
> Quoting "Samer Afach"
>> Thank you for your reply.
>> Actually I'm concerned now before this with the question whether the
>> envelope algorithm offers the envelope as a function and not surfaces,
>> because I couldn't find a single function in the corresponding class
>> that does that. Does it do that? I mean I would like to give it a
>> polyhedron, and on the other side using minimum and maximum get the
>> envelopes as functions of x and y, is that possible?
>> I'd appreciate any efforts so much,
>> Thank you,
>> Samer
>> wrote:
>>> You need to use an exact-predicate and exact-construction kernel. If
>>> you do that and the problem still occurs, please send the entire
>>> (small) program that reproduces the problem.
>>> Quoting
>>>> Hello,
>>>> I eventually have found that the planes are being taken in the
>>>> right way
>>>> by dereferencing the iterator, but the program is failing in giving
>>>> the
>>>> right envelope, and giving an unexplainable exception, I started to
>>>> believe that the algorithm has a problem... here's the part of the
>>>> code,
>>>> where P is a closed polyhedron object
>>>> for(plane_it = P.planes_begin(); plane_it !=
>>>> P.planes_end();++plane_it)
>>>> planes.push_back(Surface_3(*plane_it));
>>>> cout<<*plane_it<<endl;
>>>> //this is a part where the example inserted the points
>>>> planes.push_back (Surface_3(Plane_3(-1, 0, 1, 0)));
>>>> planes.push_back (Surface_3(Plane_3(0, 1 , 1, 0)));
>>>> planes.push_back (Surface_3(Plane_3(1, 0, 1, 0)));
>>>> // Compute and print the minimization diagram.
>>>> Envelope_diagram_2 min_diag;
>>>> CGAL::lower_envelope_3 (planes.begin(), planes.end(), min_diag);
>>>> std::cout << std::endl << "The minimization diagram:" <<
>>>> std::endl;
>>>> print_diagram (min_diag);
>>>> // Compute and print the maximization diagram.
>>>> Envelope_diagram_2 max_diag;
>>>> CGAL::upper_envelope_3 (planes.begin(), planes.end(), max_diag);
>>>> std::cout << std::endl << "The maximization diagram:" <<
>>>> std::endl;
>>>> print_diagram (max_diag);
>>>> The polyhedron I'm using has like 30 facets or more, and is closed and
>>>> follow the Euler characteristic, and I could view it using
>>>> Geomview. So
>>>> I'm very confused and don't know where the error could be. The
>>>> exception
>>>> differs everytime because I'm every time generating a new polyhedron
>>>> that
>>>> fulfills the conditions mention. here's the error I'm getting in
>>>> Terminal:
>>>> terminate called after throwing an instance of
>>>> 'CGAL::Precondition_exception'
>>>> what(): CGAL ERROR: precondition violation!
>>>> Expr: cv.has_left()
>>>> File: /usr/local/include/CGAL/Arr_linear_traits_2.h
>>>> Line: 682
>>>> Aborted
>>>> and here's another one too:
>>>> Expr: f == f2
>>>> File:
>>>> /usr/local/include/CGAL/Arrangement_2/Arrangement_on_surface_2_impl.h
>>>> Line: 2639
>>>> Explanation: The two halfedges must share the same incident face.
>>>> Aborted
>>>> This last error I can't understand, what does the envelope thing
>>>> have to
>>>> do with the halfedges? I'm giving the program plane equations and
>>>> it has
>>>> nothing to do with my polyhedron.
>>>> Any effort is highly appreciated,
>>>> Thank you,
>>>> Samer Afach
>>>>> Hello programmers,
>>>>> I have a question since I'm not a professional C++ programmer. I'm
>>>>> trying to apply the 3D envelope example 32.3.3 in
>>>>> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Envelope_3/Chapter_main.html
>>>>> but I'm taking the planes from a polyhedron, and I have them in the
>>>>> type
>>>>> Plane_3 through the iterator Polyhedron::begin() to end(). The
>>>>> example
>>>>> takes them in the form Surface_3(Plane_3()), how can I do this
>>>>> transformation? I tried to use std::transform for this but I failed.
>>>>> The example provides it using the 4 coefficients of a plane, I can
>>>>> see
>>>>> these coefficients of my Plane_3 object on a cout stream, but I can't
>>>>> extract them alone one by one.
>>>>> Could you please either tell me the correct transformation method for
>>>>> this or tell me how to extract the coefficients from my Plane_3
>>>>> object?
>>>>> Thank you,
>>>>> Samer Afach
>>>>> You are currently subscribed to cgal-discuss.
>>>>> To unsubscribe or access the archives, go to
>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
