cgal-discuss - Re: [cgal-discuss] From Plane_3 to Surface_3
  • To:
  • Subject: Re: [cgal-discuss] From Plane_3 to Surface_3
  • Date: Wed, 24 Mar 2010 11:07:43 +0100
This function does not take my point on the plane and return the
projection, this function gives some kind of organisation of the
surfaces over the of the plane, and in the case of planes it creates the
lower envelope as a surface, but does not give any values! here actually
lies my problem! isn't this the best thing it can do?
Thank you,
Samer
wrote:
> Quoting "Samer Afach"
>> But I've seen in the envelope program that it already supports triangles
>> just like it supports planes with two different examples with similar
>> outputs, isn't this the case? what's the difference between the
>> implementation of triangles or planes equations? and I went through the
>> functions in the reference manual in that class and couldn't find the
>> function I need. Could you please tell me what's the name of that
>> function if you know it?
> CGAL::lower_envelope_3() ???
> I believe that the lower envelope of planes will not get you the
> desired answer. Again, unless I misunderstand your problem.
>> Thank you,
>> Samer
>> wrote:
>>> One way to do it is to triangulate the polyhedron facets (in case they
>>> are not triangles to start with) and then compute the envelope of all
>>> triangles. Consult the manual for further information. There are also
>>> examples you can use as a starting point.
>>>> Exactly! That's what I'm looking for actually! But could you please
>>>> tell
>>>> me how to implement it? does the envelope class have such a function?
>>>> Thank you,
>>>> Samer
>>>> wrote:
>>>>> If you are looking for a function that accepts a polyhedron and a
>>>>> point in the plane and returns the point on the lower envelope of the
>>>>> polyhedron, the vertical projection of which coincides with the input
>>>>> point, then you can implement it using the existing functionality.
>>>>> Otherwise, I don't understand your question.
>>>>>> Thank you for your reply.
>>>>>> Actually I'm concerned now before this with the question whether the
>>>>>> envelope algorithm offers the envelope as a function and not
>>>>>> surfaces,
>>>>>> because I couldn't find a single function in the corresponding class
>>>>>> that does that. Does it do that? I mean I would like to give it a
>>>>>> polyhedron, and on the other side using minimum and maximum get the
>>>>>> envelopes as functions of x and y, is that possible?
>>>>>> I'd appreciate any efforts so much,
>>>>>> Thank you,
>>>>>> Samer
>>>>>> wrote:
>>>>>>> You need to use an exact-predicate and exact-construction
>>>>>>> kernel. If
>>>>>>> you do that and the problem still occurs, please send the entire
>>>>>>> (small) program that reproduces the problem.
>>>>>>> Quoting
>>>>>>>> Hello,
>>>>>>>> I eventually have found that the planes are being taken in the
>>>>>>>> right way
>>>>>>>> by dereferencing the iterator, but the program is failing in
>>>>>>>> giving
>>>>>>>> the
>>>>>>>> right envelope, and giving an unexplainable exception, I
>>>>>>>> started to
>>>>>>>> believe that the algorithm has a problem... here's the part of the
>>>>>>>> code,
>>>>>>>> where P is a closed polyhedron object
>>>>>>>> for(plane_it = P.planes_begin(); plane_it !=
>>>>>>>> P.planes_end();++plane_it)
>>>>>>>> planes.push_back(Surface_3(*plane_it));
>>>>>>>> cout<<*plane_it<<endl;
>>>>>>>> //this is a part where the example inserted the points
>>>>>>>> planes.push_back (Surface_3(Plane_3(-1, 0, 1, 0)));
>>>>>>>> planes.push_back (Surface_3(Plane_3(0, 1 , 1, 0)));
>>>>>>>> planes.push_back (Surface_3(Plane_3(1, 0, 1, 0)));
>>>>>>>> // Compute and print the minimization diagram.
>>>>>>>> Envelope_diagram_2 min_diag;
>>>>>>>> CGAL::lower_envelope_3 (planes.begin(), planes.end(),
>>>>>>>> min_diag);
>>>>>>>> std::cout << std::endl << "The minimization diagram:" <<
>>>>>>>> std::endl;
>>>>>>>> print_diagram (min_diag);
>>>>>>>> // Compute and print the maximization diagram.
>>>>>>>> Envelope_diagram_2 max_diag;
>>>>>>>> CGAL::upper_envelope_3 (planes.begin(), planes.end(),
>>>>>>>> max_diag);
>>>>>>>> std::cout << std::endl << "The maximization diagram:" <<
>>>>>>>> std::endl;
>>>>>>>> print_diagram (max_diag);
>>>>>>>> The polyhedron I'm using has like 30 facets or more, and is
>>>>>>>> closed and
>>>>>>>> follow the Euler characteristic, and I could view it using
>>>>>>>> Geomview. So
>>>>>>>> I'm very confused and don't know where the error could be. The
>>>>>>>> exception
>>>>>>>> differs everytime because I'm every time generating a new
>>>>>>>> polyhedron
>>>>>>>> that
>>>>>>>> fulfills the conditions mention. here's the error I'm getting in
>>>>>>>> Terminal:
>>>>>>>> terminate called after throwing an instance of
>>>>>>>> 'CGAL::Precondition_exception'
>>>>>>>> what(): CGAL ERROR: precondition violation!
>>>>>>>> Expr: cv.has_left()
>>>>>>>> File: /usr/local/include/CGAL/Arr_linear_traits_2.h
>>>>>>>> Line: 682
>>>>>>>> Aborted
>>>>>>>> and here's another one too:
>>>>>>>> Expr: f == f2
>>>>>>>> File:
>>>>>>>> /usr/local/include/CGAL/Arrangement_2/Arrangement_on_surface_2_impl.h
>>>>>>>> Line: 2639
>>>>>>>> Explanation: The two halfedges must share the same incident face.
>>>>>>>> Aborted
>>>>>>>> This last error I can't understand, what does the envelope thing
>>>>>>>> have to
>>>>>>>> do with the halfedges? I'm giving the program plane equations and
>>>>>>>> it has
>>>>>>>> nothing to do with my polyhedron.
>>>>>>>> Any effort is highly appreciated,
>>>>>>>> Thank you,
>>>>>>>> Samer Afach
>>>>>>>>> Hello programmers,
>>>>>>>>> I have a question since I'm not a professional C++ programmer.
>>>>>>>>> I'm
>>>>>>>>> trying to apply the 3D envelope example 32.3.3 in
>>>>>>>>> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Envelope_3/Chapter_main.html
>>>>>>>>> but I'm taking the planes from a polyhedron, and I have them
>>>>>>>>> in the
>>>>>>>>> type
>>>>>>>>> Plane_3 through the iterator Polyhedron::begin() to end(). The
>>>>>>>>> example
>>>>>>>>> takes them in the form Surface_3(Plane_3()), how can I do this
>>>>>>>>> transformation? I tried to use std::transform for this but I
>>>>>>>>> failed.
>>>>>>>>> The example provides it using the 4 coefficients of a plane, I
>>>>>>>>> can
>>>>>>>>> see
>>>>>>>>> these coefficients of my Plane_3 object on a cout stream, but I
>>>>>>>>> can't
>>>>>>>>> extract them alone one by one.
>>>>>>>>> Could you please either tell me the correct transformation
>>>>>>>>> method for
>>>>>>>>> this or tell me how to extract the coefficients from my Plane_3
>>>>>>>>> object?
>>>>>>>>> Thank you,
>>>>>>>>> Samer Afach
>>>>>>>>> You are currently subscribed to cgal-discuss.
>>>>>>>>> To unsubscribe or access the archives, go to
>>>>>>>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
