cgal-discuss - Re: [cgal-discuss] Re: Call for participation to the Google Summer of Code
  • To:
  • Subject: Re: [cgal-discuss] Re: Call for participation to the Google Summer of Code
  • Date: Thu, 25 Mar 2010 16:20:49 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:content-type; b=AVhLY++Tw9/ZTcCwbw//8DU+LN8QatX2bNqSgkMB4ORUfQ9tPXQDzS029TWbnd1gqM VACLokTWrpMsCUqD4kXRWC8c5TaPx75qPsBHeawCS9Yuc7yavH4RuFBYYB+X3mEmZrMD LvGrvzIpe/TaqR0eLt4xd/mtHpTZqbNX8CMU4=
Hi Avishek,
> Dear All,
> Can somebody help me out in knowing about the CGAL algorithms that are
> actually Randomised or
> ask for users for some sort of random object generator as inputs ?
It turns out that we don't already have any list of uses for random
numbers within CGAL.
OTOH, there is one and only one class, CGAL::Random, that is used for that.
I did a grep for that class and it showed up in a number of places
(geometric generators, some algorithms, and test suites). Since a
significant part of this GSoC involves understanding and refactoring
the code to use the new RNG models, I figured that it would be a very
useful learning oportunity if you do the grep yourself and familiarize
with the code that needs to be refactored.
Of course, you are free to ask me directly about any specific piece of code.
> It will be also nice if you can help me in knowing those random object
> generators as well, which are used in several CGAL algos ?
Right now there is only one (CGAL:Random). It is documented and it's
fairly simple
Best
Fernando
