- To:
- Subject: Re: [cgal-discuss] moving point in ConstrainedTriangulation
- Date: Wed, 07 Apr 2010 16:20:11 +0200
Hello,
have you tried to use functions
remove(Vertex_handle v) and insert(Point p)
to mimic the move? is it to slow?
S.
piR wrote:
Hi everyone,
This is I guess a pretty stupid question but I just cannot seem to make it
work properly.
I need to move a point within a triangulation. For that aim, I use the Vertex_handle->setpoint(Point) function a bit
recklessly.
Usually the new positions are almost the same as the previous ones (it is a
relaxation step), so it seems to work fine.
But of course, since I do not properly check whether the predicates are
still verified after the move, there are cases where my triangulation gets
corrupted.
Would you mind helping me doing this properly?
I tried to backtrack according to the result of the is_valid() functions,
but to no avail.
I swear I looked around, and only found a solution for a more restrictive
Delaunay triangulation somewhere.
Am a total CGAL newbie and this needs to work asap.
MANY THANKS!
- [cgal-discuss] moving point in ConstrainedTriangulation, piR, 04/07/2010
- Re: [cgal-discuss] moving point in ConstrainedTriangulation, Sebastien Loriot (GeometryFactory), 04/07/2010
- Re: [cgal-discuss] moving point in ConstrainedTriangulation, pierre, 04/07/2010
- Re: [cgal-discuss] moving point in ConstrainedTriangulation, Daniel Duque, 04/08/2010
- Re: [cgal-discuss] moving point in ConstrainedTriangulation, pierre, 04/08/2010
- Re: [cgal-discuss] moving point in ConstrainedTriangulation, Pedro Machado Manhães de Castro, 04/08/2010
