cgal-discuss - Re: [cgal-discuss] moving point in ConstrainedTriangulation
  • To:
  • Subject: Re: [cgal-discuss] moving point in ConstrainedTriangulation
  • Date: Thu, 8 Apr 2010 10:56:47 +0200
  • Organization: UPM
Hello,
You may consider the move function. It should be inherited from
Triangulation_2.
For some reason, this function is not documented, but it's right there in the
code. If you have a look, you can see that the process is indeed not that
simple ( include/CGAL/Triangulation_2.h )
BTW, the fact that move is not documented anywhere is a bit unsettling for
me,
since I've been using it quite a lot (actually the Delaunay move(), which is
redefined, not just inherited). In my case, it is because I am using a loop
over vertices, and moving them. An insert + removal would modify the loop
iterator.
Best,
Daniel
On Wednesday 07 April 2010 16:42:47 pierre wrote:
> Well, sorry for being so confusing (and for the typo in your name).
> To make things simple, I must keep my Vertex_handles untouched at all cost.
> Actually, all I need is to find the set of proper tests for detecting and
> preventing any combinatorial changes from happening if I move my vertex so
> that I can backtrack.
> But I just cannot seem to have those tests right. I must forget something
> ... :S
> On Wed, Apr 7, 2010 at 4:26 PM, pierre
> wrote:
> > Hi Sebastian,
> > Actually I need to keep my Vertex_handles intact.
> > This algorithm is basically some kind of a greedy triangulation growing
> > thing (with a lot of computations going around)
> > and I need to keep track of the recently-added vertices so that I can
> > process them later on. I typically store the to-be-processed
> > Vertex_handles in a priority_queue from which I pop the vertex to
> > consider.
> > Am afraid that using remove(V) and insert(P) will generate another handle
> > and compromise the validity of the pointers stored in my
> > queue.
> > But thanks for your quick reply anyway. :)
> > Pierre.
> > On Wed, Apr 7, 2010 at 4:20 PM, Sebastien Loriot (GeometryFactory) <
> > wrote:
> >> Hello,
> >> have you tried to use functions
> >> remove(Vertex_handle v) and insert(Point p)
> >> to mimic the move? is it to slow?
> >> S.
> >> piR wrote:
> >>> Hi everyone,
> >>> This is I guess a pretty stupid question but I just cannot seem to make
> >>> it
> >>> work properly.
> >>> I need to move a point within a triangulation. For that aim, I use the
> >>> Vertex_handle->setpoint(Point) function a bit
> >>> recklessly.
> >>> Usually the new positions are almost the same as the previous ones (it
> >>> is a
> >>> relaxation step), so it seems to work fine.
> >>> But of course, since I do not properly check whether the predicates are
> >>> still verified after the move, there are cases where my triangulation
> >>> gets
> >>> corrupted.
> >>> Would you mind helping me doing this properly?
> >>> I tried to backtrack according to the result of the is_valid()
> >>> functions, but to no avail.
> >>> I swear I looked around, and only found a solution for a more
> >>> restrictive Delaunay triangulation somewhere.
> >>> Am a total CGAL newbie and this needs to work asap.
> >>> MANY THANKS!
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://debin.etsin.upm.es/~daniel
