cgal-discuss - Re: [cgal-discuss] Two problems from beginner: version selection and Install manual
  • To:
  • Subject: Re: [cgal-discuss] Two problems from beginner: version selection and Install manual
  • Date: Thu, 8 Apr 2010 12:01:32 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=qrJBGB8iz1z/NF2cUoMJ4CcWE5hF3U97mR6uQzKbvGHev4MNVVaq1V/wBl2+1bCSop OOIG9hvVd104SpKc4ESc9RjTzoQiOXcN3dPkmVVDYy0X4iZNab+f16kkKkk4VYkXnFDI boWk4+ug3MXbxuht2A6LQxKcI+Sc0n9ozMK/E=
Hi toetal,
The following works fine for me:
CGAL3.6
Qt 4.6.2
Boost_1_38
Cmake 2.8.0
Visual Studio 2008
Following the instructions in the link you included is very useful and will likely help you a lot. In case of any problem, you need to google or try and error to resolve the issues.
Good luck,
-Ramin
2010/4/8 toetal <>
I just touch this CGAL, two problems from a beginner like me:
1.Which version of CGAL, Boost and Qt respectively seems easy and robust for new user to install and further learning?
2.To Installing CGAL and related programs on Windows, just refer to Install manual or
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows? The former seems a little officialese. The latter is very detaied and useful, but there were alway errors in my configuration, is it apply to the new version of CGAL and boost?
How did you make it? Will somebody give your option or suggestion, or perhaps some more information?
Thanks a lot!
