- To:
- Subject: Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?
- Date: Thu, 8 Apr 2010 09:03:29 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=Message-ID:X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=5viSmGn+D6msuzEgtYccy97i+wTnVkLQIoPoYPjVXS8LjqNdraiWofEiOJum1utV/CxmxZGMkdv9rlCzCgTcaEmjwwd03TAvtL/jToeC9TslNJjE2/YsGB0wXUB4EkqfLS/elwDuvF0bQtKWiwUFmai3NzgxsH3E3ZPPN8aQz9o=;
I see that the CGAL is more or less .cpp and header files, I'm searching but
can't find anything pertaining to compiling or needing to compile CGAL
libraries anywhere in the manual. Just CMake stuff, <Configure> and
<Generate>.
Help. If there's a make or build file in, or for, CGAL, I can't find it. Or
anything about it in the manual.
--- On Thu, 4/8/10, Laurent Rineau (GeometryFactory)
wrote:
> From: Laurent Rineau (GeometryFactory)
> To:
> Date: Thursday, April 8, 2010, 8:44 AM
> On Thursday 08 April 2010 09:48:00 A
> S wrote:
> > What is this 'CGAL-vc90-mt.lib'? Does this thing
> even exist in the world?
> > It's not in the CGAL 3.6 download.
> The Windows installer of CGAL>=3.4 no longer install
> precompiled libraries.
> You need to compile CGAL libraries after CGAL is install.
> You better read the
> installation manual! ;-)
> http://www.cgal.org/Manual/last/doc_html/installation_manual/contents.html
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory
> http://www.geometryfactory.com/
> Release Manager of the CGAL Project
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?, A S, 04/08/2010
- Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?, Laurent Rineau (GeometryFactory), 04/08/2010
- Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?, A S, 04/08/2010
- Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?, t doehring, 04/08/2010
- Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?, Sebastien Loriot (GeometryFactory), 04/08/2010
