cgal-discuss - Re: [cgal-discuss] Problems on segment Voronoi diagram
  • To:
  • Subject: Re: [cgal-discuss] Problems on segment Voronoi diagram
  • Date: Fri, 23 Apr 2010 09:43:27 +0300
  • Authentication-results: MX-IN-05.forthnet.gr ; spf=neutral
  • Authentication-results: MX-IN-05.forthnet.gr ; sender-id=neutral
Try using CGAL::Simple_cartesian<CGAL::Gmpq> as your exact kernel. Also using the segment Delaunay graph hierarchy should make things faster.
There are also other alternatives for constructing the segment Delaunay graph even faster, but they apply only if you know all your input in advance (i.e., they are not incremental).
As far as the problem with more than 5000 segments is concerned, please send the data, along with the actual code you used to compute the segment Delaunay graph, so that I can take a look at them.
- m.
On 23 Apr 2010, at 05:36, Vu, Khuong wrote:
Hi there,
I think what you did was good. I got the same thing working with Voronoi diagram. I guess it is the problem of Voronoi diagram adapter.
You can check if it is by constructing the DELAUNAY diagram of the same set of input instead of Vornoi diagram. If it runs reasonably fast, then it is the Voronoi adapter to have trouble. You can look at the header definition of the SegmentDelaunayGraph demo. The declaration should be good for you since it deals with no strongly intersection. However, it is Delaunay. Constructing the Voronoi still runs pretty slow though.
Please let me know if you need further help. I have written an alternative Voronoi adapter, currently just for myself. But I'm now away from my desk.
Khuong
________________________________________
Sent: Thursday, April 22, 2010 8:01 PM
To:
Subject: [cgal-discuss] Problems on segment Voronoi diagram
I am constructing Vornoi diagrams using CGAL, the segments are all from a
polygonal line, they are consecutive, and there are
weak intersections as CGAL describes.
Firstly,I chose MP_Float as the data type for EK, however, the running
time is rather slow,
even slower than the results given in the corresponding papar<< A robust and
efficient implementation for the segment Voronoi diagram>>
in 2004.
Then, I chose Simple_cartesian<double> as EK, this time the running time is
rather short , however, the checking function is_valid()
returns false. And for segments more than 5000, the program corrupted.
Could someone give a trait and policy configurtion ,under which I can build
Voronoi diagram of a polygonal line efficiently? Thank you
The following is my current configuration(under which the program runs
quite slow, if replace EK with Simple_cartesian<double>,
the build time is short but for more than 5000 segments the program
corrupts):
typedef CGAL::Quotient<CGAL::MP_Float> ENT;
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Simple_cartesian<ENT> EK;
typedef
CGAL ::Segment_Delaunay_graph_filtered_traits_2 <CK,CGAL::Field_with_sqrt_tag,
EK, CGAL::Field_tag> Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt> SDG2;
typedef CGAL::Segment_Delaunay_graph_adaptation_traits_2<SDG2>
TRAIT;
typedef
CGAL::Segment_Delaunay_graph_caching_degeneracy_removal_policy_2<SDG2>
POLICY;
typedef CGAL::Voronoi_diagram_2<SDG2,TRAIT,POLICY> SEG_VD;
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2023020.html
