- To:
- Subject: Re: [cgal-discuss] RE: Problems on segment Voronoi diagram
- Date: Fri, 23 Apr 2010 12:32:59 +0300
I am not really sure about that. I am attaching my version of your code, where I made some modifications. You will notice that I have commented the usage of Quotient<MP_Float> and replaced it by Gmpq. Also I have commented the usage of Segment_Delaunay_graph_2 and replaced it by Segment_Delaunay_graph_hierarchy_2. Also I am considering two possible ways of inserting the segments: your way (the simple/obvious way) and inserting the first endpoint of a segment, then the second using the vertex_handle returned for the first, and then use the two vertex handles to insert the interior of the segment (I call this below the polyline insertion method, whereas the first one is called the segments' method).
Here are my running times (on a PowerPC G4) in seconds with optimization flags turned on (Release building mode):
SDG + MP_Float + polyline: 35.5918
SDG Hierarchy + MP_Float + segments: 35.6429
SDG + Gmpq + segments: 1.19534
SDG + Gmpq + polyline: 1.17302
SDG Hierarchy + Gmpq + segments: 1.14345
SDG Hierarchy + Gmpq + polyline: 1.17157
It seems to me that the showstopper is the number type. I would immediately switch to Gmpq, and also use the hierarchy (it will be much for efficient for more input segments). I you do not want to use the hierarchy, then use the alternative way of inserting your input (this is the insertPolyline function in the code).
- m.
main.cpp
Description: Binary data
On 23 Apr 2010, at 11:46, Bai wrote:
I just run your code,
I think the reason lies in the use of
Segment_Delaunay_graph_degeneracy_removal_policy_2, there may be some
degeneracies in Voronoi diagram and such denegeracies are rejected by such a
policy.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2036497.html
- [cgal-discuss] Problems on segment Voronoi diagram, Bai, 04/23/2010
- RE: [cgal-discuss] Problems on segment Voronoi diagram, Vu, Khuong, 04/23/2010
- Re: [cgal-discuss] Problems on segment Voronoi diagram, Menelaos Karavelas, 04/23/2010
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/23/2010
- RE: [cgal-discuss] RE: Problems on segment Voronoi diagram, Vu, Khuong, 04/23/2010
- Re: [cgal-discuss] RE: Problems on segment Voronoi diagram, Menelaos Karavelas, 04/23/2010
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/28/2010
- RE: [cgal-discuss] RE: Problems on segment Voronoi diagram, Vu, Khuong, 04/28/2010
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/29/2010
- Re: [cgal-discuss] RE: Problems on segment Voronoi diagram, Menelaos Karavelas, 04/29/2010
